Results 1 to 5 of 5
Thread: Oil feed for supercharger /turbo charger
    Vk ls1 turbo
    Aug 2009
    townsville
    Default Oil feed for supercharger /turbo charger
    hey i need a bit of help with feeding my turbo with oil. i don't really want to tap the sump if i don"t have to. i heard about people using other source to feed it and using a inline 12 volt pump on the return to keep the oil flowing. any body know where i could find more info or any think on oil feed systems for a forced feed ls1
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    best and most common spot to get the feed from is the little plate above the oil filter
    you need to tap the sump for the return line not the feed
    the scavenging pump is used for low mount turbos to return the oil to the sump not to feed it
    feed line is a pressure line so it doesnt use or need a pump
    cheers GM
    Vk ls1 turbo
    Aug 2009
    townsville
    can i return it into the oil filler cap as i have seen this done on some setups i just don't want to tap the sump
    2002 HSV GTO COUPE
    delcowizzid's Avatar
    delcowizzid is online now on holiday
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you can but you will need a scavnge pump to suck the oil from the turbo outlet to the rocker cover any pressure in the return blows seals
    Vk ls1 turbo
    Aug 2009
    townsville
    riteo no worry's thanks for that
    2002 HSV GTO COUPE
  1. [SA] turbo charger
    By GEORGEZ in forum Parts And Other Items For Sale
    Last Post: 19-11-2009, 10:40 PM
  2. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  3. turbo 202 oil feed lines
    By evl83h in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-03-2009, 10:10 PM
  4. [SA] wtb oil feed line conect for turbo
    By nasty1 in forum Swap / Wanted to Buy / Trade
    Last Post: 22-01-2009, 04:48 PM
  5. Turbo Charger Info
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 09:06 AM
