i am wondering what else is need to do a manual conversion beside the obvious.. i.e, does the speedo hook straight up? , will the reverse lights work? and will the pcm / bcm be all good? do i need a loom or anything? cheers guys
You need the manual loom, or you will need to redo the wiring.
PCM will need to be retuned
pcm does not have to be fully retuned they just change it for a manual i was quoted 80 bucks to do it
thanks for the replys gonna stick with the auto when there shift kitted there so much fun anyway...
