Results 1 to 15 of 15
Thread: lsa help
    vs III commodore ute
    Sep 2008
    Default lsa help
    ok first of all, im getting a cam installed thinking 227-231 112lsa.. i want a really lumpy sounding cam. ive been told the lsa with determine how lumpy your idle is.. but i cant find any forum giving a straight forward answer.. ( The lower the lsa the more lumpy? or is it the higher the lsa the lumpyer?)
    with that question answerd will the 227-331 112lsa be nice and lumpy?
    thanks for your help guys
    My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
    BradSV8's Avatar
    BradSV8 is offline Nitrous Junkie
    VY SV8
    Feb 2005
    I already told you this in the other thread but here a link for you too read thru.
    *** Cam Guide *** - LS1TECH
    ENHANCED Cammed & Nitrous SV8
    10.43 @ 133mph
    Sep 2008
    yeh mate, i read something some where then i read the oppisite on a different forum. ill have a read of that tho
    VN Calais 5.0L
    Feb 2006
    The lower the LSA the choppier it will be.....
    I have a 110 LSA on my 224/228. The size of the overlap will also determine the chop
    carless for now
    Feb 2007
    perth,Western Australia
    if you tell your tuner i want it lumpy as f**k he can tune it like that also depends on the cam
    Sep 2008
    ok thanks for all ya help guys
    VT SS LS1
    Oct 2008
    gold coast
    WHII Statesman
    Sep 2006
    Geelong, VIC
    LSA has a decent impact on the lumpyness of the note, but also changes a few things like powerband, PTV and potential power.
    The lumpyness can also be tuned to an extent. Different idle mixtures and timing advance will change the note.
    This is my 227/234/113 on a cold idle (~975rpm).
    YouTube - WH Statesman L76 227/234/113 Cam Tuned Idle
    VX Berlina Wagon V8 A4
    Dec 2008
    Quote Originally Posted by SirNemesis View Post
    That's tuff as mate!! Does the same principle with the tune apply to a stock or bolt-on LS1?? For example, if I had a catback and CAI and went for a tune I could specify a lumpier idle?? Are there any downsides that you know of with this...i know mine will never sound as sweet as yours but im looking for every little bit without breaking the bank.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    The same would apply to a stock or bolt-on LS1, but as for any downsides, the answer to that is outside my tuning knowledge. I'd assume that it would be a compromise, as a lumpier idle with less timing advance will also reduce manifold vacuum, which lessens the effects of vacuum assisted brakes and will probably hurt idle fuel economy aswell.
    Dec 2008
    Thanks mate...ill look into it as im just about to get a full dyno tune done.
    BradSV8's Avatar
    VY SV8
    Feb 2005
    Here is mine warm idle 226/231 110 LSA
    YouTube - Cam idle
    And at the track with no exhaust
    http://www.youtube.com/watch?v=SHVBE3GFpaA
    10.43 @ 133mph
    VX Calais LS1 Turbo
    Jun 2005
    Sounds nice bloke but it would sound nicer with a hair dryer hanging off the side
    WHII Statesman
    Sep 2006
    Geelong, VIC
  15. #15
    dosent matter
    Jun 2010
    Default ok
    well its like this if you want lump you need overlap period
    with overlap comes scavaging which means unburnt fuel and air in the exhaust
    with EFI engines unburnt gases make it hard to tune the engine
    so that is why the EFI engines generally run wide lobe seperations which means less overlap so speak to your tuner and see if he can tune something with a round 240 at 50 and 108 lobe seperation thats not too tight and should work and give you lots of lump if your tuner says "no" find one that can because it can be done
