Results 1 to 10 of 10
Thread: help needed pcv hose's for vortech blower setup
    Vk ls1 turbo
    Aug 2009
    townsville
    Default help needed pcv hose's for vortech blower setup
    Hey i need some help hooking up all the pcv hose's on my supercharger set up for my vx. i have taken the hose out of the throttle body and blocked that off. where do i run th hose from the drivers side tappet cover dose it go into the back of the blow off valve or does it go in the pipe some where near the s/c intake . a photo would really help also tanks
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
    Vk ls1 turbo
    Aug 2009
    townsville
    hose A is connected to the rocker cover and not sure where it breaths to can i hook it up ti the intake tube in front of the s/c inlet
    hose B is hooked onto the BOV where does it go to and i all so have 4mm hose about 300mm long and a few 4mm t pieces. any help would be great
    also is any thing ment to go into the little hole in the back of the blower discharge pipe i have a bung for it but any hose's or anything ?
    2002 HSV GTO COUPE
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i dunno which line on an LS1 has the pcv valve in it but that line will need to be plumbed in on the inlet manifold side of the throttle body. because the pcv is only open under vacuum, thats when the motor expels its crankcase pressure back into the inlet tract via the pcv.
    bov line will have to be plumbed into the same spot, well not the exact same but after the t/b somewhere. so when u back off the gas the bov line sees vacuum and lets the bov open. there is a thread in the ve section asking about plumbing a catch can, check it out the diagrams there might be of use to ya
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    Vk ls1 turbo
    Aug 2009
    townsville
    thanks for that mate. could i plumb the bov one into the heater vac hose that goes into the back of the manifold near the map sensor
    2002 HSV GTO COUPE
    VS 5L M5 VS 6L M6
    Apr 2009
    if the bov line is similar diameter to the heater line and can be 'tee-d' into it i reckon it should be ok
    Avoid cluey police
    Vk ls1 turbo
    Aug 2009
    townsville
    thanks mate i will give it a go.
    2002 HSV GTO COUPE
    VZ SS Blown 5.7 A4
    Jan 2010
    run it into the flexible intake hose before the blower if you pm me ur munber i will text you a pic cheers
    Vk ls1 turbo
    Aug 2009
    townsville
    hey cheers mate i got it all sorted now
    2002 HSV GTO COUPE
    VZ SS Blown 5.7 A4
    Jan 2010
    Vk ls1 turbo
    Aug 2009
    townsville
    yea its pretty crazy ay i just need to sort my power steering out power steering help. ASAP i have no power steering
    2002 HSV GTO COUPE
  1. [QLD] vortech v1 blower kit!
    By 17UCK! in forum Parts And Other Items For Sale
    Last Post: 01-01-2010, 02:44 PM
  2. [ACT] Vortech blower and accessories
    By YVR05L in forum Parts And Other Items For Sale
    Last Post: 26-11-2008, 04:48 PM
  3. F.s Vortech v2 blower kit
    By VL2Di4 in forum Parts And Other Items For Sale
    Last Post: 03-05-2008, 10:05 PM
  4. Replies: 16
    Last Post: 19-02-2005, 10:04 AM
