Results 1 to 8 of 8
Thread: HELP: Inlet manifold
    vx ss
    Apr 2010
    Default HELP: Inlet manifold
    I got my vxss s1 LS1 back from service last week and they in formed me that the leak was from the vally gasket. I went to my local car shop and they informed me that this is a intake manifold gasket. When i pulled apart this and changed them and put it all back i found my car had no engine Temp. Could doing this gasket change broken something? whats my next step?
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    check coolant temp sensor plug near thermo i think?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    vy ss commodore 5.7ltr
    Jul 2006
    yeh check the plugs near the back off the manifold and wiring, i left 2 off when i did my valley plate gasket by accident, one was throwing a fault code and one wasn't, just check and trace all the wiring around the inlet manifold and you'll either find one disconnected or a broken wire.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Plugs towards the back of the manifold are for oil pressure and cam position. The one you are looking for is on the front corner of the passenger side head. People often lean on these which results in them breaking, or it could just simply be not connected.
    vx ss
    Apr 2010
    well they are all conected so i think i have broken it :S. off to the mechanic 2morrow.
    Thanks for the help guys
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    Did you end up finding out what the problem is?
    Ill have a guess that it was the sender
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    vx ss
    Apr 2010
    Nope when i was driveing the car to the shop it seem to get temp agen and hasnt mist a beat since.
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    it may have been a little loose until you checked it
    I haven't lost my mind, it's backed up on tape somewhere
  1. Inlet manifold... DOH!
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2011, 04:46 AM
  2. l67 inlet manifold
    By Adrian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2008, 12:46 PM
  3. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  4. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  5. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
