Results 1 to 6 of 6
Thread: ls1 misfiring when warm
    evl55 is offline evl55
    vy ss ute
    Feb 2008
    Default ls1 misfiring when warm
    ok, problem that i have had for a couple of weeks now and its driving me nuts. when car is cold it runs beautiful, but once warm it runs very rough, surges etc, only under about 2000rpm, when it does it, to accelerate it hesitates a little then goes great. once at revs or full throttle its fine. i have changed leads, fuel filter, injectors, coolant temp, cleaned tb, checked for vac leaks, still no go. no codes are being thrown either. the car is vy ss, 6 speed, 230/230 112 comp cam, otr and mafless tune. twin 2.5 exhaust. any help please????
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    uhmm fuel regulator?? air filter, dirty TB, IAC? uhmm trying to think....foo-foo valve? lol
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    vy ss ute
    Feb 2008
    pulled tb off yesterday and cleaned the whole lot including iac and tps. air filter is clean as. foo-foo valve... hmm could be onto something there haha
    Sphinx's Avatar
    Sphinx is offline O.G.
    VX Calais II LS1
    Aug 2005
    Pakky
    take it to a tuner and get them to stick it on a dyno and see what going on. see what's happening in closed loop mode, check AFRs, stuff like that.
    The Calais
    Sleeper Club
    VT SS S2 A4
    Aug 2005
    Had a similar problem and turned out that it was the O2 sensors, and they were not throwing any codes either.
    blown vy v8 ute
    Jul 2009
    02 sensors ... mine did put out a code . had the same problem
  1. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  2. misfiring..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-07-2006, 11:24 PM
  3. VN Misfiring
    By LMac in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 01:31 AM
  4. Misfiring?
    By ryan_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-05-2006, 08:26 PM
  5. misfiring....
    Last Post: 29-04-2006, 06:06 PM
