Hi all.. Looking for a little advise here.... I am in the process of installing a Growler Cold Air Induction unit (VX Series 1 V8) and all I have left to do is replace the temperature sensor unit. In the old airbox the sensor was positioned after the filter but before the MAF unit. With the new airbox, there is no place the the temp sensor can be placed in the same position as the old. It can only be placed before the filter or after the MAF unit. Is there a 'correct' position it should be placed.. ie before..or after as above. Feedback wuold be much appreciated..... Thanks...
Yip it should be placed in the MAF pipe between the MAF and the throttle body. The factory pipe has a hole with a grommet for it
