Results 1 to 2 of 2
Thread: turbo help for LS1???
    vy ss commodore 5.7ltr
    Jul 2006
    Default turbo help for LS1???
    I'v been looking at some turbo set ups and found a turbo, but unsure if it will be good on a ls1, its a t4 turbo commonly used on rx7's, this turbo i'm looking at is of a soarer drag car, after reading a couple of things i'm unsure if it will be ok, have read it is only suited to high revving rotary, 4 and 6 cylinder engines, and read that the turbine is too big and won't produce power till too late in rev range, also comes with an external wastegate and an apexi blow off valve, apparently was producing around 10psi mark.
    the specs are from what iv found on the net for the turbo going buy the part no:
    T4 Rotary / FC3S FD3S RX7 TURBO CHARGER
    Specifications
    Nomenclature (tag ID)
    Inlet (exducer/hot side)
    T-4 Flange 70.1mm x 82.55mm (2.76” x3.25”)
    Outlet (exducer/hot side)
    Sized for press fit or weld in V-Band adaptor
    Inlet (compressor/cold side)
    Ř 76mm (3”)
    Outlet (compressor/cold side)
    Ř 52mm (2”)
    Exducer A/R
    1.15 (sized for Mazda rotary motors)
    Compressor Style
    0.60
    Bearing Type
    plain
    Cooling/Lubrication
    Oil/Oil
    Oil Supply Fitting
    NPT Threads
    Oil Return Fitting
    Flange
    Compressor major diameter
    Ř 69 mm
    The “T4 Rotary” turbo is suited for perfectly for high exhaust energy motors. It is a perfect fit to the Mazda rotary motors. Larger Toyota, Honda, Mitsubishi, 4 and 6 cylinders seeking 475HP+ with very fast spool. This combination of AR (Hot/Cold) results in a quick spooling turbo for the Mazda motors. Other motors should consider resizing the exducer housing to change lower the RPM at which peak boost is achieved. We offer a wide range of supporting add-ons: Intercoolers, blow-off valves, supply lines, inlets, stainless intercooler tubing, intakes, waste gates, turbo manifolds, headers, etc.
    T-4 manifold gasket
    Priming instruction sheet
    Oil Return Flange Gasket
    any help greatly appreciated or a recommended turbo greatly appreciated,
    Ben.
    VX S S/C & BA XR6T
    Feb 2009
    Checkout the Borgwarner turbos,great value for money.
    Give the above a miss imo.
    https://turbodaves.com/Home_Page.html
  1. [SA] vl turbo motor/trans/microtech/fmic/gtr/plenum/turbo + vs v8 5spd conversion
    By nasty1 in forum Parts And Other Items For Sale
    Last Post: 18-05-2010, 07:58 PM
  2. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  3. GROUP BUY TURBO - GENUINE GARRETT TURBO GT35/40R 700Bhp
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 21-12-2006, 12:14 PM
  4. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
