ok i got a cam installed ran fine got it tuned ran fine. then 100kms after install it started stalling at lights. i thought it was a tune problem. my tuner found out there was no oil pressure. oil pump ###ed? so my question is.. is it the installer of the cams fault or sometime they just go after camswaps?
thanx guys
and has any1 paid to get oilpump changed if so how much?
My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
The key question is how was the cam swap done? I would imagine it was done by not removing the engine nor dropping the sub frame to allow the sump to be removed. If is was done by simply removing the timing cover etc then the problem is aligning the oil pick up. This is practically impossible to do unless you remove the sump. I could only guess, but I imagine your oil pickup is not lined up which is why you have no oil pressure.
the engine was out of the car at the time off cam swap. so it might not be that.
you dont need to drop the oil pump to do a cam change.
VS S3 would be a 5ltr.
Fairly sure the timing cover wont come off without pulling the pump off. Did it today, but the whole lot had to come off anyway so I didnt arse about.
hahah fair enuff. so whys it in the lsx forumn
cam retaining bolt wasn't done up?
Body by Holden, Soul by Brock
the Legend will live forever
its an ls1 thats y its in the lsx.
its in the shop at the moment so ill soon find out if it was the mechanics fault or just bad luck.
thanks for the help guys ill let you know what happens.
good luck buddy, from what the last owner of my ute said, he never had any problems when he got the cam done on my ute. im gessing it was just bad luck. but good luck anyway dude. i hope it was their fualt so it wont cost you an arm and a leg.
want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
it was something about the double row timing chain not being installed properly. but ill be goin back to the place to get a refund of the labour to fix it.
