so ive got a cracked head. GAY!. so im goin 2 get performance heads. what brands dose every1 recommend and prices? ive got a 227/231 112 cam. so im hoping for the 400hp mark. thanks guys
My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
Edelbrock
Dart
Trick Flow
Higgins CNC heads
Kostecki CNC heads
All of the above would suffice.
Something with a slightly smaller comustion chamber to raise compression ratio slightly and CNC ported is what you would be after.
If you can get hold of another head cheap enough and send them away to Higgins im sure for just under $3,000 you would get a wicked set of heads back, best bet is to ring him and have a chat.
Thats what i would do.
He may even have a spare one lying around, you never know.
Becareful were you get your heads from buy from a reputable company, seen a CV8 add only 4rwkw's from a set of so called ported heads.......
buy et performance heads they cost shit loads but are the best
or you could call egal auto parts the gm suplier and get some lsx 454 heads they flow the same as the ls7 and have the same ports but you will need a fast or ls7 manifold
just buy some used heads and send them to higgins i think its 1700 to port and they usually have good track results
{H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
just got myself a 218/224 114lsa cam, what would be a good valve size for my heads on intake and exhaust or does anyone have any numbers for who i can call to get a price, going to use the heads that are on the car and get them ported with upgraded/ bigger valves but not sure what size to go for, not after huge numbers just a decent set to go with the cam to help it breath a little bit better or not worth it on a mild cam? Already got new pushrods, 918 valve springs, thinking about new lifters at same time so while heads are off may as well do it if worth it.
the cost of porting the head wouldnt be worth it for that cam
cool, thanks, yeh that's what i was thinking today, i know some people with big cams and stock heads and been fine, thinking for that extra bit, but going to throw it in now and get it tuned.
