Results 1 to 5 of 5
Thread: help with replacing waterpump for ls2 6l
    Vz Clubsport ls2 A4
    May 2005
    Unhappy help with replacing waterpump for ls2 6l
    Water pump in my vz clubby ls2 has just gone and just wondering what has to come off the engine to replace the waterpump just not sure,some guy at hsv said they have have replaced a few waterpumps in vz ls2 6l's best price i got on the waterpump was $335 for waterpump plus gaskets $12 plus 5 litres of coolant $50,and also airconditioner belt has gone squelling as well have to replace but it is a tricky to get to as have been told have to rip out the twin thermo fans' and radiator to get to that area and use a breaker bar to change it.
    Any advice guys on what to do would help a lot.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    What they have told you is the correct method, i would also advise some loctite on the crank bolt when you torque it up.
    http://forums.justcommodores.com.au/signaturepics/sigpic58904_1.gif
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    Crank bolt???????????????????
    I did mine a few months ago and all i took off was
    The radiator shroud/cover
    Intake pipe, maf and throttle body
    Serpentine belt
    Top radiator hose
    You can remove and replace the belt tensioner once you have the water pump out as its only attached to the water pump
    That was on an LS1 but I cant see there being much difference
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    Aug 2009
    Radelaide
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    i was able to replace the a/c belt in my vy without removing the radiator or fans. it is a thigh squeeze but defiantly do able.
  1. Vt 5.0l Waterpump
    By leviathan_333 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2010, 01:55 PM
  2. vs v8 waterpump?help needed
    By hold on boy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2009, 05:19 PM
  3. vn v8 waterpump question
    By whatawookie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2009, 09:19 AM
  4. vp waterpump
    By elba in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2008, 10:49 PM
  5. Gen 3 LS1 Heads & Waterpump
    By Pub247 in forum Parts And Other Items For Sale
    Last Post: 06-01-2007, 10:44 PM
