Results 1 to 8 of 8
Thread: Ls1 otr
    VTSS GEN3, VKSSA REP V8, VP BT1 V8
    Feb 2006
    darlington
    Default Ls1 otr
    hey guys, lookn into OTR intakes at the moment, just not sure wat kind to get.. been told the alloy ones are just going to get hot and then just end up maken the air ya suck on hot witch wouldnt be any differant to a pod intake, but the plastic ones warp and flex.
    is there a way to some how put a heat shield between the alloy OTR and the radiator? just not sure what to do at the moment. or do i just go for a growler intake?
    BAD COP!! NO DONUT!!
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Not true. While stationary it will heat up just like anything else but once you're moving it is stone cold. I have an alloy OTR on my SS and I've actually checked this.
    Feb 2006
    darlington
    ah k, what about like stop start city driveing when ya cant real get a free run to suck much air in?
    Oct 2006
    Bogan enclave
    I don't think what it is made of is going to make a difference to heat absorbency. If it is in a hot engine bay it is going to heat up. What do you expect?
    Aluminium will dissipate that heat quicker than most other materials though. Why do you think amplifiers have aluminium heat sinks?
    I'm not sure why you'd even be worried about it? Pod set ups draw hot air from a hot engine bay. OTR's draw air from out of the engine bay. I'd base the choice on which one you think looks nicer because there's nothing between them in terms of performance imo.
    VZ SS
    Aug 2009
    Maitland NSW
    I'd go a DUS intake for your LS1. They flow pretty well and look nice too. Growler? Dont even waste your time. They are called SS Reductions for a reason lol
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    i agree with you vz ss i have one and they are the good and work well
    Experience is a hard teacher. First you get the test, then you get the lesson.
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    OTR CAI is the way to go - Any of them over any of the Growler/ SS Restriction or just doing the K/N filter - 2nd hole mod shite.
    vs ute
    Sep 2008
    aluminum alloy will not just dissipate the heat quicker it will also heat up quicker so there isnt always a positive there and yes it has everything to do with the material that is used.
    to the topic starter you can buy heat wrap stuff that has a sticky backing and is quite thick, im going to wrap the underside of mine in it to stop the transfer of heat from the top of the rad but mine is not the aluminum one its just the plastic one i think or maybe its fiberglass not sure it hasnt arrived yet.
