Interest in who is using what LS1 single turbo kit and have you had any manufacturing faults like cracking exhaust manifolds, turbo failures, etc? What power figures have you made, with what modifications eg injectors, cam, throttle body, exhaust etc.
i had a mixture of pcpa stuff and custom stuff. stay away from pcpa. trouble from the start crossover pipe did not fit and dump pipe hit on the body and manifold bolt holes did not line up.lol . i sold it all befor i even got it all on so not sure about what power it made just stay away from there manifolds and what not. They will try sell you the steam off there sh!t to press your pants with too. they will tell you there is nothing wrong with there stuff once you complane. I learnt my lession.
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
Cool because I was going to talk to them tomorrow about a kit as they have them advertised on special. This is the kind of feed back I was looking for.
Check out the ASE turbos. I don't have one but know of a few people who do and they're very happy with them.
PM sent re turbo.
GenRacing
I've got a GenR1000 kit on my WH. Well made manifolds, but a few little areas that require a bit of creativity during the install. Certainly nothing trivial though. I dont have any power figures yet from my car, but I'm not sure if it will be relevant for you anyway as I've got an L76 conversion and a turbo grind cam.
Shane does have some results up on the websites from his stock LS1, stock auto VX calais that will show you what his kits are capable of.
im running a ssv with a 402 stroker kit and single t1000 turbo kit from ase and its brilliant, tuning is the biggest problem but as for the gear iv had no real issues and iv been driving it as a daily for a while now. if you do go down the line of a single large turbo, i recomend getting some sort of bonnet scoop, heat rapping everything and getting it ceremic coated before you install it as the under bonnet temperatures soar. im having a bit of trouble with my fuel system as the fuel is vaporising and stalling the engine after a few hours of constant stop start driving. if you have any ideas on this problem im keen to hear them.
just to add to that, mabe think about getting/making a larger coolant resivour than the one that ase provides, and power wise im making around 470rwkw on 10psi
I've got a mixture of Genracing bits on mine (intercooler kit, turbo manifolds, dump pipe) - after a few cuts were made everything fit perfect - very happy with all of their gear. I run a turbonetics t88 which is a really top notch turbo - good warranty on it too.
I have a mate who bought a PCPA kit, it was a bit of a nightmare to install (pretty much everything had to be re-drilled), the turbo (t04Z) was way too small, as was the wastegate. The fella ended up upgrading to a ching chong y2000k GT45 and a 50mm wastegate and makes 500rwhp
