Just wondering if anyone new anything about them or has one on there LS1...What are price like on the kits
I really don't think they are needed unless your car is revving fairly high most of the time
Cost Is around $300
Benifits????
My personal opinion is they are not worth it unless you are fitting a cam. The power difference you will not notice only about 2-3 rwkw.
ENHANCED Cammed & Nitrous SV8
10.43 @ 133mph
Why do they make more of a difference with a cam?
Cause stock engines wont rev to 7,000rpm where the accesories take power out of the engine due to higher rpm and loading.
As accesories do a much higher RPM due to pulley gearing.
ahh fair enough.
So basically no point on a road car at all then. Because at 7000rpm in first gear you're going to fast anyway...
That's why I said on a road car...
It's not something you'll notice everyday. So why spend the coin on it.
As I said its a waste of time unless you are fitting a cam cause the balancer has to come off anyway....
10.43 @ 133mph
To many people are only thinking of the 3rwkws you will gain but what about the other components that will now last a bit longer as they are now turning 25% slower like the power steer pump, alternator, water pump, dont you think these parts will now have an easier life?
Worth it for the $300ish I say.
You make a good point Steve but if you dont put a cam in chances are that you are not going to be reving the car that hard anyway. I reckon Holden/GM would have done a lot of testing to ensure the water pump etc etc would be up to the task in factory trim. I still do not think it is worth it unless you are doing a cam due to the parts and labour cost to fit the balancer for no real gain.
10.43 @ 133mph
Wouldn't it put more load on them things at low RPM because they're spinning slower, so you're essentially going to be forcing the issue (PS pump).
well if your putting a cam in, your bumping up the idle speed anyways, so the accessories will be spinning no slower than usual at idle.
Thanks for the insights and point of views i think i will give it a miss for now as i am planing a cam upgrade in the near future...i might look at doing it at the same time....THANKS
