Hi,
I'm just looking for opinions on ignition leads to suit the LS1. Gotta replace the stardard one as they've done 130k.
I have the money to replace them with some decent items, but whats the go with them?
Is there one brand that works better then another?
I realise there's bugger all gains to be had, but seeing as there is very little difference in price between standard and aftermarket, I figuered I would investigate.
i have top gun leads.
Reason: thats what repco had when i went in.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
Id go genuine if they have them
Thing is stock leads are more expensive then the other brands.
$160 for a set of standard leads or I can get a set of eagle 10.5mm for $120.
ohh i didnt realise that, id go eagle or topgun (if there cheaper)
Any difference between the two?
As in, any body had any real horror stories?
Commodore VY VX-Z LS1 LS2 Spark plugs &spark plug leads - eBay Spark Plugs, Ignition Systems, Car, Truck Parts, Cars, Bikes, Boats. (end time 14-Nov-10 08:21:01 AEDST)
Genuine LS1 plugs and leads for $140, bought a set myself a while back
Ahh bugger that wasn't up when I was looking. Too late.
Ahh well, I got some Eagle 10.5mm leads and GM plugs for $200. So not horrible.
What is horrible is a fugging oil pressure switch for $88.
If you can use the genuine head shields with the new leads. Have heard of the boots touching the extractors and burning through
There's tonnes of room around the pacemakers but I'll see how I go. Cheers.
did u look at the msd 1's ? i bought some yesterday from the states only 100 bucks with these exchange ratesnow i just gotta wait
Yeah, they were $200 here in aus and I need them ASAP car wasn't running. Leads and plugs were 30k over due...
Doing the o2 sensors at the same time, plus the oil pressure switch. So a $400 proposition. :S
whats the go with replacing oxy sensors, apprently mine need replacing, yet the computer doesnt have check engine, doesnt use loads of fuel etc?
done 108 000km? or is it just something people do because you should...
Just like changing spark plugs mate, just needs to be done. 100k is the normal life span apparently. For $120 for the both why not?
Driver side o2 sensor plug is a bastard on the LS1, but not imposible.
I went to holden to get a quote on leads, nearly $400 bucks they wanted for my ssv, autobarn had topgun for $180, so im gunna go with topgun lol
yeah i used topgun leads as thats what repco had lol cost me $90 trade
Just get a set from the states and save a heap..
ebay bro, i got some 10mm top guns for me old mans ss for $130, good ol ebay never fails!
My VR is a pig
Yeah I got somem 10.5mm Eagle leads for $140.
Best leads by far are the stock red vy leads $160 at motor traders I just took off a set of top gun leads and replaced with stockers.
Haven't noticed a difference either way.
Leads are leads unless they're totally rooted IMO.
I've had OEM leads snap of in my hand. Mainly because they're stuck on the plug, which I've found common on LS1's. The back drivers side especially.
For the record. ACDelco was started by the same bloke who started Champion ignition products. AC is Alfred Champion. (or Alfonz I can't remember)
