Results 1 to 4 of 4
Thread: Off idle stumble.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Default Off idle stumble.
    Hi,
    A week ago I was driving my car through town, and it decided to die in the arse.
    Missing and backfiring idling at about 500rpm and shaking like a dog. Basically felt like it was running on seven cylinders.
    I already had an engine light for the oil pressure switch, but this didn't seem to be the same issue.
    I've replaced the ignition leads, spark plugs and o2 sensors today. As well as the oil pressure switch.
    Started it up and it idles fine. But it stumbles at about 1100-1500rpm. It revs fine through the range after that.
    I'm also getting an engine light after it stumbles.
    Does anyone have any idea's?
    VX Clubsport Series II 5.7 6 Speed
    Sep 2010
    It will most likely be you PCV hose going into the throttle body. They split and crack causing engine to register lean mixture.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    Nov 2008
    Smithton, Tasmania.
    Took it for a drive this morning and it seems to be okay. I still have the engine light. But perhaps thats due to the oil pressure switch still? I might have to get the bloke with his magic black remote.
    Either way, It'll drive there now. It seriously felt rooted the other day.
  1. A.S.A.P Help with a VT Idle
    By K Lewy in forum Tuning
    Last Post: 09-11-2009, 07:27 PM
  2. idle problems. won't sit at a constant idle.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 07:59 PM
  3. vs bad idle pls help.
    By ooh304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2007, 05:31 PM
  4. Ecotec Stumble off idle.
    By squidda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 11:34 AM
  5. Bad idle 5.0
    By Richoss in forum General Discussion
    Last Post: 15-04-2005, 10:49 AM
