Results 1 to 15 of 15
Thread: Wh ls1 heads
    vs calais
    Jun 2010
    Default Wh ls1 heads
    Just wounderin if any1 can ansa a question for me
    I've been told the heads on wh statos are smaller
    ported then say Ss heads from factory?
    Any1 know if this is true? Should I replace my heads
    with Ss ones 4 better flow b4 I do a maffless tune??
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    241 heads are smaller, 243 heads are the go.
    Requires new ARP head bolts as they are different lengths.
    Also new rocker covers if you have perimiter bolt patterns and switch them to centre bolt covers and also swap out coil packs and brackets.
    http://forums.justcommodores.com.au/signaturepics/sigpic58904_1.gif
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I'm sure it would with a tune and a few other basic mods your VE would be increased and you'd gain some power and possibly better Fuel ecionomy depending on tune
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    HRT 666's Avatar
    HRT 666 is offline Cammed 8t-body stroker
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    Im not sure on the combustion chamber size on the 243 heads and what it would do to comp ratio (raise or lower it) maybe someone in the know can help us out here? I know the 243 flow a little better. Even on my stroker I stuck with the 241 and got them stage 2 cnc ported and they worked out killa.
    With heads its all about keeping the air speed high dont look for peak cfm numbers.
    Nov 2008
    Smithton, Tasmania.
    I've heard that the 243 heads don't fit the 3.9" bore of the LS1 properly.
    I know 308 heads go on 253's and the discrepancy between the 4" 308 and the 3.6" bore of the 253 would be worse. I know apples and oranges...
    HRT 666's Avatar
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    My advice for a stock motor would be keep the 241 head as it has smaller ports and will keep the air speed at lower rpm and make better torque.
    Nov 2008
    Smithton, Tasmania.
    Yeah I would anyway, just curious really.
    I wouldn't even bother porting them for mild engine. After pulling the manifold of, they're some of the sexiest factory heads I've ever seen.
    carless for now
    Feb 2007
    perth,Western Australia
    vs calais
    Jun 2010
    Ok, thanks for the advice ppl, but last question is
    should I put different heads on my wh Stato? It's goin
    in forthe tune in 4 days so, if I male the change it's gona
    need to be this wknd
    Nov 2008
    Smithton, Tasmania.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Fair bit of crazy info here. 243 heads will bolt straight onto an LS1 (3.9" bore). These are LS2 standard heads and will perform better, but probably not good enough to justify the effort involved. L76/L98 (L92) heads will not bolt onto a 3.9" bore (5364 casting number). That isn't whats being discussed here, but where the confusion has come from.
    Nov 2008
    Smithton, Tasmania.
    Fair enough, I didn't spread it as gospel. Just bought it up as I'd heard something along those lines to begin with.
    bortous is offline Mad max 101
    VZ CLUBSPORT R8
    Dec 2008
    in a house
    the 243 heads fit on ls1 and do flow more but you need to get them ported etc and increase the compression and you will notice a massive difference.
    From about 225CFM at the intake it will shoot up to about 320CFM which is huge. Still flows less than a stock l92 head but power wise not a big difference.
  15. #15
    Nov 2008
    Smithton, Tasmania.
    Seems to be completely unnecessary on a mild LS1.
  1. [Ecotec] So I have heads and a cam going in...
    By one_and_only2004 in forum V6 Development And Modification
    Last Post: 14-07-2010, 06:46 AM
  2. no oil to the heads. :-(
    By lmcd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 05:42 PM
  3. v6 heads
    By Calais_5sp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2007, 06:21 PM
  4. Vn Efi V8 Heads
    By VL2Di4 in forum Parts And Other Items For Sale
    Last Post: 06-01-2007, 12:55 PM
  5. Which Heads
    By chappy in forum General
    Last Post: 17-12-2006, 11:50 PM
