Hi guys, Quick question.
Which Model commodore has the OBDII protocol for sure?
I've read various things at different sources, some claiming that anything Gen3 is OBDII while others claim its OBDI, I know the V6's use the ALDL protocol as the 5ltr did. So can anyone here say with out a shadow of a doubt what it actually runs?
Gen 3 is OBDII. I am running Aeroforce OBDII gauges in my 2000 VT SS.
Okay, I've been told that certain scan tools wont work with a VY SS. In order to read codes and so on. That I need an OBDI scan tool to read it.
Your plug should be under the steering wheel.
I know where the plug is, but that doesn't indicate which protocol its using, VS 5ltrs have the same plug but use the ALDL protocol.
Gen3's use the OBDII protocol SAE J1850 (VPW), while Gen4's use ISO 15765 (CANBUS).
Okay, only reason I ask is because I asked the seller of this item:
OBD2/EOBD SCAN TOOL VY VZ VE BF FG Autel Maxscan GS500 (eBay item 200445531973 end time 28-Nov-10 02:23:08 AEDST) : Cars, Bikes, Boats
And was told that I needed this item to work on my VY:
MaxiDiag US703 GM/Holden Ford OBD2 Scanner Code Reader (eBay item 190396645333 end time 09-Nov-10 22:36:00 AEDST) : Cars, Bikes, Boats
He then told me it was due to the fact that the VY used the OBDI protocol.
And that only the VZ and VE use OBDII, which didn't make sense. Seems that the VE has the CANdi protocol.
Here is the transcript of our conversation:
Hi, I'm looking into getting one of these scanners for my car. Its a 2003 VY SS, with an LS1 Gen3.
I read that it will need a different model of scanner is this the case?
If so, what is the cost of it?Yes, you need Us703 to works on your car. and it is only scanner works on Vy on current market in this price arrange.
it is $249
check here for detail:
Best regards
WilsonBugger, is the extra $100 worth it?
I mean in all honesty?
Does it do anything different to the item I was looking at? (Other then work? haha)no, it doesn't do extra work, it just an Obd1 and obd2 scanner.
the one you looked is OBD2 scanner only.
and your car is obd1 car.
Best Regards
WislonOh fair enough, I was under the impression that all Gen3 engines run the OBDII protocol.
The VN to VY V6 engines all run the ALDL protocol is that correct?Im not calling the bloke a liar, but its all very confusing.no, only VZ and VE of Holden is OBd2, else model is OBD1
Thought it seemed a bit weird. Might find another seller.
Thanks for your help everyone.
Found this site for anyone who is interested.
http://www.autoscanners.com.au/index...&products_id=8
Description:
FORD FALCON AU BA BF FG XR6 XR8 TERRITORY & MORE
HOLD COMMODORE VT VX VY 5.7L LS1 GEN3 0BD1 CORVETTE
LIVE DATA READS & CLEARS DOMESTIC & IMPORTED FORD CODES
ENGINE LIVE DATA. ABS AIRBAG DIAGNOSTIC SYSTEMS OBD1
A Scan tool that Will Read Australian FORD and HOLDEN
AU - BA - BF - FG
VT - VX - VY - VZ - VE
This Scan tool is not only for OBD2
it has the FORD and Holden software codes loaded.
It reads AUSSIE FALCON and COMMODORE when others will not.
If you have the following models you can check your ENGINE - AIRBAG - ABS systems [note. will not read AUTO TRANS before BF at this time].
AU all series 6cyl & v8 XR6 & XR8 ENGINE, ABS, AIRBAG System Codes.
BA all series 6cyl & v8 XR6 & XR8 ENGINE [live data via Obd2 function] ABS, AIRBAG System Codes.
BF all series have full Obd2 compliance, ENGINE [live data via Obd2 function] ABS, AIRBAG, AUTO System Codes
This Scanner is also designed for GM {American based} so it works on the following COMMODORES.
VT - 5.7L LS1 - Engine live data, ABS, Airbag Systems (not V6)
VX - 5.7L LS1 - Engine live Data, ABS, Airbag Systems (not V6)
VY - 5.7L - LS1 - Engine live data, ABS, Airbag Systems (not V6)
also
VZ - V6 & V8
VE - V6 & V8
via the OBD2 Program.
This will clear Fault Codes from Engine, ABS, Airbag System & Codes logged from - BCM - ENGINE Electronics etc.
Live Data on the VE shows the following -
Amount of Diagnostic Trouble Codes.
Fuel System 1 status.
Fuel System 2 status.
Calculated Load Value. %
Engine coolant Tempersture. C
Short Term Fuel Trim - Bank 1.
Long Term Fuel Trim - Bank 1.
Short Term Fuel Trim - Bank 2.
Long Term Fuel Trim - Bank 2.
Engine RPM.
Vehicle Speed Sensor. [kph]
Ignition Timing Spark Advance.
Intake Air Temp. C
Mass Air Flow Sensor [g/s].
Absolute Throttle Position %
O2 Sensor Output Voltage. B1S2
O2 Sensor Output Voltage. B2S2
Protocol. - EOBD - OBDSUP.
Time Since Engine Start.
Commanded Evaporative Purge.
Fuel Level Input %.
No of Warm-ups Since DTC cleared.
Distance Since DTC Cleared. [kms].
Barometric Pressure.
Equivalence Ratio [wide range O2S] [ B1S1]
O2 Sensor Current [wide range O2S] [B1S1}
Equivalence Ratio [ wide range O2S] [B2S1]
O2 Sensor Current [wide range O2S] [B2S1]
Catalyst Temp Bank 1 Sensor 1.
Catalyst Temp Bank 2 Sensor 1.
Control Module Voltage.
Absolute Load Value. %
Ambient Air Temp. C
Absolute Throttle Position B.
Accelerator Pedal Position D.
Accelerator Pedal Position E.
Commanded Throttle Actuator Control
TheVZ & VE has MISFIRE MONITOR so the scanner will tell you which Cylinder has an Electrical problem.
Over 7000 Fault Codes.
the VT VX VY have the following live data
Fuel system open/closed loop.
Coolant Temp deg C.
Short term fuel trim %.
Long term fuel trim %.
MAP InHg.
RPM.
Vehicle speed. Kph.
Spark advance.
IAT deg C.
Absolute TPS %.
All O2 Sensors.
Calculated Load.
Lamda readings.
Memory/ battery backup.
ALSO READS.
Misfire Monitor.
Fuel System Monitor.
Comphrensive components Monitor.
Heated Catalyst Monitor.
Catalyst Monitor.
Evap. System Monitor.
Sec. Air System.
A/C Refrig. Monitor.
O2 Sensor Monitor.
O2 Sensor Heater.
EGR System Monitor.
OBD2 Protocol Display.
FEATURES.
Works with all 1996 & later USA, European & Asian vehicles.
Suitable on Australian vehicles from 1999. [VARIES ON MODELS & MANUFACTURERS}
Reads & clears Generic OBD2 Trouble Codes.
Reads & clears Selected OBD2 Manufacturer Specific Codes.
Turns off CHECK ENGINE light [MIL]
Views FREEZE FRAME data.
Performs MODULES PRESENT TEST.
Reads PCM LIVE DATA STREAM.
Displays LIVE O2 Sensor Test data.
Displays Monitor & I/M Readiness Status. [emissions] & Misfire Monitor.
Retrieves VEHICLE INFORMATION NUMBER. [ VIN]
C.A.N BUS [controller area network] high & low capability.
Built in DTC library.
Upgradeable via USB port.
Reads Codes for POWER TRAIN inc. CHASSIS, BODY, & NETWORK. over 7000 codes. [depending on vehicle].
ABLE TO READ MORE OBD2 COMPLIANT VEHICLES THAN OTHER SCANNERS.
HOLDEN. FORD. MITSUBISHI. HONDA. SUBARU. KIA. DAEWOO. PROTON. TOYOTA. NISSAN. JAGUAR. MERCEDES. RENAULT. JEEP. CHRYSLER. BMW. PEUGEOT. VW. AUDI. ISUZU. HYUNDAI. MAZDA. RANGE ROVER...via OBD2 program
EASY TO USE, SIMPLE YES/NO FROM MENU.
PLEASE NOTE... Not all vehicles have all of these features, and the operation of the scanner relies totally on the on-board software of the VEHICLE.
Due to variations in compliance in AUSTRALIAN vehicle years, it is not possible to supply a list of compatibility here.
CONTACT US FOR MORE INFO. BUT PLEASE SUPPLY MAKE, MODEL, BUILD DATE & ENGINE TYPE. OR WE CANNOT RESPOND......
Please see the feedback from our Customers on Ebay
LIVE DATA. WATCH THE READOUTS AS YOU DRIVE.
All postage has been insured, so never have to worry about lost mail.
interested but $250 is more than i wanna spend
more interested in the <$100 units off ebay or dealextreme
Apparently they don't work.
F@#k wish i had seen this thread like half an hour ago just brought 1 of these units.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
Well the US703 should work. If thats what you've got.
Let me know how it goes eh?
^^^will do.
Cool, I was going to get it anyway, but its always good to NOT be the guinea pig.
Hey soop tried to catch you in the CB , my us703 arrived today have only had about 20mins play but it worked on the ss an on the missues cruz will put up a thread when i have had more time to play with it.
Sounds great. I'm keen to get one then!
Good thing I saw this thread before going out and buying a scan tool.
So the US703, which is the $249 one on eBay, is the way to go?
Tom.
Seems that way!
Hey tom yeah the us703 works well with my vx s1 ss an my jg 09 cruz so should go good with the vt if thats what you got it for.
Is there anythings that it doesn't do?
So far it has done everything that it says it will do for the VX soop all the live readings work can veiw an delete codes thats about all i have done with it so far Using the live data i found out that my TPS is the cause of all my idle/RPM issues it wasnt returning to 0% all the time after relaseing the throttle lucky i had a spare 1 changed it over an now all good. Is pretty kool crusing around with it hooked up an watching all the data change as you slow down or speed up.
