Results 1 to 22 of 22
Thread: LS1 blocks.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Default LS1 blocks.
    Hey guys,
    Looking to have a crack at building an LS1. just looking for some information.
    I was under the impression that the LS1's used alloy blocks, if so can someone explain this;
    LS1, LS2, 6.0L Cast Iron Block (eBay item 290502850527 end time 01-Dec-10 10:33:10 AEDST) : Cars, Bikes, Boats
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    LS1 car blocks are aluminium. I think the cast iron were used in GM truck applications. Happy to be corrected though.
    Nov 2008
    Smithton, Tasmania.
    That's what I was sumerising too. It's good to get it confirmed.
    Does anyone know where I can get a block?
    Either a blown motor or a new block depending on $$?
    ve sv6
    Aug 2010
    Quote Originally Posted by wikky View Post
    correct, these are truck blocks, also some tuners prefere the iron block to the alloy block because there is less distortion and movement, making them stronger.
    VZ SSZ
    Mar 2008
    Here
    Soop, Eagle Auto Parts down in Dandenong are a massive GM parts dealer. 92 South Gippsland Highway, Dandenong VIC 3175 (03) 8710 3000
    They'd sell truckloads of these so you may get one cheapish.
    Nov 2008
    Smithton, Tasmania.
    I want to build a fairly strong motor, but I'm not to sure if the weight of the cast iron block is worth it, it seems fairly cheap though.
    What are alloy blocks worth?
    VT
    Apr 2005
    QLD
    If it were me, I'd be going big boost, so I would be going to either a 6 litre iron block or an LSX block.
    Really depends what you want to do with it. If you are putting it in a light car and want to keep the weight down, an aluminium block is the way to go.
    Nov 2008
    Smithton, Tasmania.
    Its going into a VY, and I'm staying NA.
    350kw would be heaps for me, I just like NA power.
    VT
    Apr 2005
    QLD
    Quote Originally Posted by soop View Post
    Then an alloy block it is, then.
    Before you go buying stuff, check this out:
    UltraStreet High Performance Crate Engines By Scott Shafiroff Race Engines
    Shafiroff are good to deal with.
    ve sv6
    Aug 2010
    Nov 2008
    Smithton, Tasmania.
    Thanks for the link, but I want to build it myself. Thus Why I'm looking for a block .
    Does anyone have an idea of what a brand new block is worth without a rotating assembly?
    VT
    Apr 2005
    QLD
    Nov 2008
    Smithton, Tasmania.
    My budget is what ever it ends up costing :P.
    I'm not going to do it over night, so its not a really issue.
    If I can get a full motor for $2500 surely the block is worth shit all.
    carless for now
    Feb 2007
    perth,Western Australia
    the iron blocks are mostly for big power fi or if forged internals are going in. if you are looking for 350rwkw just stick with a alloy
  15. #15
    WHII Statesman
    Sep 2006
    Geelong, VIC
    A few months back you could get LS1/LS6 5.7L blocks for about $550 new, but I believe they are closer to $900 now. Iron 6L (LQ9) blocks are about the $1100 mark.
  16. #16
    Nov 2008
    Smithton, Tasmania.
  17. #17
    WHII Statesman
    Sep 2006
    Geelong, VIC
  18. #18
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    As far as i know the cast iron block only weights about 50kg more than the alloy 1 anyways, i know what 1 i would be choosing
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
  19. #19
    Nov 2008
    Smithton, Tasmania.
    Gah, I hate shopping on the internet.
    I can only find create motors on eagle.
  20. #20
    WHII Statesman
    Sep 2006
    Geelong, VIC
  21. #21
    Vk ls1 turbo
    Aug 2009
    townsville
    warhawk lsx block if you want the best.
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
  22. #22
    Nov 2008
    Smithton, Tasmania.
    Yeah I'll have to give them a call..
    Sorry Wikki Didn't even see that you had mentioned them previously.
  1. Roller blocks.
    By soop in forum V8 Development and Modification
    Last Post: 13-08-2010, 08:42 PM
  2. Lowering Blocks
    By SAMO-87 in forum General
    Last Post: 28-04-2008, 07:23 PM
  3. 2 x ea1000D mono blocks
    By bMcgrath84 in forum Parts And Other Items For Sale
    Last Post: 31-01-2008, 05:26 PM
  4. Distribution blocks - where?
    By MasterOfReality in forum Car Audio
    Last Post: 10-01-2005, 10:03 AM
