Results 1 to 15 of 15
Thread: LS1 cam selection
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    Default LS1 cam selection
    hey guys was just wondering if you could lend me a hand with my cam selection
    ill try and give you as much information as i can
    its for a VXII SS, 70,000 kms on it, auto.
    Mods will be pacemakers, hi flows, and a twin 2.5 inch catback, OTR, and 4.11 diff gears.
    Car isnt daily driven, so therefore i will be looking for a cam with an aggressive street presence/idle.
    if you can steer me in the right direction that would be awesome
    vy ss commodore 5.7ltr
    Jul 2006
    i'm not an expert on this but something in the high 220's to low 230's on a 112, but best advice i was given was go for a drive in some with different cam specs and see what you like, you might like how one feels to you over another, i went for a drive in a ls1 with a low to mid 230's from memory that was more for FI and i liked it but have gone for a mild cam as i have been driving mine a bit more than i thought i would lately and not putting a bigger torque converter in (unless my factory one gives up on me).
    Give your local tuner or a couple of different tuners a call and explain what your looking at doing and if they have any cars or customers cars that you might be able to go for a drive in and see what you prefer.
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    The Comp 232/234 @112lsa off the shelf cam would be ideal for what you seem to want, coupled with a 3500 or so stall. Not my cup of tea, but it would be a stout package with the 4.11 diff.
    cheers
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by macca33 View Post
    cheers
    whys that mate? is it a pig or?
    as i said its more a project car, gets driven twice a week, once to work, once back again.
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    No, not saying that - it would be a very quick car, just that the cam isn't my cup of tea. I drive an M6 and have just put a 215/223 in mine, as i like smaller cams that come on earlier in a manual. In an auto, the stall converter puts you straight into the torque, so it doesn't create such issues.
    cheers
    HRT 666's Avatar
    HRT 666 is offline Cammed 8t-body stroker
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    cheers
    Spot on Macca but I would be going with a 3800 stall in that combo, you could even go 110lsa with the bigger stall would sound nuts.
    2007 wm caprice
    Nov 2010
    cobar
    cheers
    that should see an 11 sec slip no probs either and will sound tuff as nails
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    im keen on fitting this cam...just want to know what else would i need to fit to get the most out of it?
    most of the cars on youtube fitted with this cam have a twin 3 inch exhaust, i was just looking at a twin 2.5.
    i know ill need new valve springs, what else would you guys run as well?
    im looking at getting the most for my money the first time around.
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Going in to get this cam and a stallie fitted
    Bit worried about driving a stalled auto, does anyone have and problems driving a stalled auto day to day? Is it much different over standard?
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Quote Originally Posted by DM 55 WA View Post
    Well it shouldnt be an issue as you said you only drive it twice a week not day to day
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    There's no rocket science to driving a stalled auto. Just drive it like you used to, except jumping on the go pedal will flash the converter. So depending on stall speed, it can have a 'slingtshot' effect.
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by XStatic64 View Post
    This is true now, I'm trying to think ahead though lol
    So for example if my gf drives my car she wouldn't know it's stalled? Should just drive fine until stomping the go pedal?
    VZ SSZ
    Mar 2008
    Here
  15. #15
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    The stal size will be selected to suit the cam (looking at a comp 232/234)
  1. 304 Cam selection
    By VTClubby98 in forum V8 Development and Modification
    Last Post: 26-11-2010, 03:30 PM
  2. vh tacho pin selection
    By TY318 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-08-2010, 08:27 PM
  3. 304 cam selection & where to buy
    By jimmyd17 in forum V8 Development and Modification
    Last Post: 11-01-2010, 04:56 PM
  4. amp selection
    By clyde in forum Car Audio
    Last Post: 07-11-2007, 06:29 PM
  5. Cam selection
    By hotvrv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 04:29 AM
