Results 1 to 14 of 14
Thread: Vx ss 6.2 ls3 conversion
    VX SS LS1
    Oct 2010
    Chinchilla Qld
    Default Vx ss 6.2 ls3 conversion
    Hey Just wondering weather any one has converted there LS1 equiped Commodore to an LS3 just wanted to get some info on what i need to change i.e (gearbox, wiring and fuel system) also what sort of coin am i going to be looking at for a brand new motor
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Aug 2004
    sounds good in theory but if you do the sums its pretty crap.
    power vs effort vs cost
    vy ss commodore 5.7ltr
    Jul 2006
    imagine what an ls1 could be like with that 10-15k spent on it compared to a standard ls3.
    VX SS LS1
    Oct 2010
    Chinchilla Qld
    HMM thanks for the ideas and the help im at the point were im not to sure weather i want to keep my LS1 150 000 klm on it and rebuild it with tuff internals or start fresh with a brand new motor weather it be LS1,2 or 3 and go with a N/A setup or Forced Induction...either way its a big decsion that im not in any hurry to make quickly i want to way up all my options and work out which is best for my budget of about 10k to 15k....Also Reliablity is a big part in it as my nearest decent performance shop is 300klm+ away...And Simplicity as majority of work will be done by me...im open to any ideas although at this stage im leaning towards a turbo setup...any HELP would be apprecaited
    carless for now
    Feb 2007
    perth,Western Australia
    how much power are you looking for? the cammed l98 is a very popular combo for around 450rwhp
    VX SS LS1
    Oct 2010
    Chinchilla Qld
    some were bettween 450rwhp and 600rwhp...but how hard would it be to put a L98 in a VX and what sort of money would i be looking at for a motor
    carless for now
    Feb 2007
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    i'd go an bigger motor over the LS1. more cubes= BIG HP!!!!!
    if i knew the price for an short block LS3, i would have not wasted my money on a 12K blower for my LS1.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    2008 Lumina Ute SS
    Jan 2011
    South Africa
    I just imported a LS3 in the crate for one of my customers
    We swapping out the stock L98 6.0L froma 2008 SS UTE and fitting the LS3 with all the groceries (cam, cold air, FAST intake etc)
    Will let u know when its done
    May 2010
    Mount Isa
    but in the end mate,
    i would rather a stroked LS3 over an F/I LS1. i made the mistake for not doing enough research. i'v just spent 12K on a blower ( thats just the blower) i still have to spend another 2.5K to install it. i also have to upgrade my cam, fuel system, and exhuast system. i will end up spending +15K after its bolted in.
    15K would get you one mean N/A LS3. i have seen short block LS3 for 7K. an stroked LS3 would have all the tourqe in the world over and built LS1.
    VX SS LS1
    Oct 2010
    Chinchilla Qld
    So what sort of power would i be looking at roughly if i was to just cam, MAFless tune and flow the heads on an LS3...Also how would my auto gearbox go would it bolt up to an LS3 motor
    WHII Statesman
    Sep 2006
    Geelong, VIC
    BradSV8's Avatar
    BradSV8 is offline Nitrous Junkie
    VY SV8
    Feb 2005
    yep 350 rwkw is def possible with a cammed LS3. I have seen a cammed LS3 in a ve go 11.0 on the quarter so in a lighter vt - vz should be capable of a 10 sec pass with the right setup. It is not cheap tho but you can save a lot by doing the work yourself and researching before you buy any parts. Several places in the states are doing built 418-427 ci LS3 short blocks for around $4.5k to fully assembled long blocks for 8k.
    ENHANCED Cammed & Nitrous SV8
    10.43 @ 133mph
LinkBacks (?)
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
Tags for this Thread
