Results 1 to 5 of 5
Thread: Autel Maxidiag US703
    Commodore M6
    Jul 2010
    East Coast
    Default Autel Maxidiag US703
    who's got one and who's been finding it useful?
    the big OBD thread seems to be gone
    i'm just playing around with the live data stuff so far
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Yep have 1 very helpful so far i have used it in my vx an on the misses jg cruz as well.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    This will help you abit Tony:
    B1 Left Side of engine drivers side
    B2 Right Side of engine Passengers side
    S1 Left Side of engine drivers side before catalytic converter
    S2 Right Side of engine drivers side after catalytic converter
    DTC_CNT 0 (Diagnostic Trouble Code Count)
    FUELSYS1 OL (Fueling Mode (OL Open Loop CL Closed Loop)
    FUELSYS2 OL (Fueling Mode (OL Open Loop CL Closed Loop)
    LOAD_PCT(%) 3.5 (not sure? Peak Torque Curve)
    ECT(�C) 38 (Engine Coolant Temperature)
    SHRTFT1(%) 0.0 (Short Term Fuel Trim Left Bank)
    LONGFT1(%) 4.7 (Long Term Fuel Trim Left Bank)
    SHRTFT2(%) 0.0 (Short Term Fuel Trim Right Bank)
    LONGFT2(%) 4.7 (Long Term Fuel Trim Right Bank)
    MAP(kPa) 65 (Manifold Air Pressure Kpa)
    RPM(rpm) 145 (yeh)
    VSS(km/h) 0 (Vehicle Speed Sensor)
    SPARKADV(�) 11.0 (Spark Advance)
    IAT(�C) 25 (Intake Air Temperature)
    MAF(g/s) 2.14(Manafold Air Flow Grams/Sec)
    TP(%) 0.0 (Throttle Position)
    AIR_STAT OFF (not sure)
    O2SLOC B1S1---B2S1--- (not sure)
    O2B1S1(V) 0.555 (o2 sensor voltage Left Bank)
    SHRTFTB1S1(%) 0.0 (02 sensor short term fuel trim Left Bank)
    O2B1S2(V) 0.445 (02 sensor voltage Left Bank, o2 after cat)
    SHRTFTB1S2(%) 99.2 (O2 sensor short term fuel Trim Left Bank, o2 after cat)
    O2B2S1(V) 0.605 (o2 sensor voltage Right Bank)
    SHRTFTB2S1(%) 0.0 (O2 sensor short term fuel Trim right Bank)
    O2B2S2(V) 0.445 (o2 sensor voltage Right Bank, o2 after cat)
    SHRTFTB2S2(%) 99.2 (O2 sensor short term fuel Trim right Bank, o2 after cat)
    That is the shit right there thanks soop an the1
    VH SLE 5.0i
    May 2009
    Wollongong
    Has anyone tried the US703 to reset the SRS codes on the LS1 equipped commodores i.e. VTII onwards. I have a VXII LS1 berlina and was considering purchasing this scanner for this car.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    lol ironically I have a thread in the VZ section about using it on VZ (I only found this thread when it suggested it at the bottom of the forum)
    I can confirm for VZ it doesnt talk to the SRS module whatsoever, despite the seller telling us it would then changing his story, but more intense reasearch on my behalf and I got confused, so Ive left it there.
    It definately has access to SRS in other cars when you flick through the manual options (like 2005 Pontiac Y series) so I'm interested to know for curiosity
  1. Code scanner question US703
    By sleepa in forum General
    Last Post: 01-08-2010, 08:42 PM
