Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Kingston_99
Thread: ls1 turbo setup street legal ? few other questions
    vt ss II 5.7
    Nov 2010
    B town
    Default ls1 turbo setup street legal ? few other questions
    so i have seen the light and am interested in making some power with a ls1 instead of playing with old 6s and other older motors.
    have been looking at a website which sells turbo kits for ls1 setups Welcome to LS1 Turbo - LSX Turbo Kits, Gen-T Turbochargers, Gen-TT, Gen-TTR
    few quick questions, are these setups street legal ? or are they a race only setup ?
    i live in victoria if it helps.
    im thinking of getting a twin turbo setup on a unopened ls1, and will just be pumping low boost( not going to be breaking shit, just want something out there)
    if i were to purchase such a kit, does it require much mods to the car to fit?
    will i need a better cooling system ?
    injectors?
    will my auto be able to handle this power/ torque increase? or will it be a bit too much for it? its currently fitted with a shift kit, std converter.
    also will the diff be capable of holding in there okay?
    if it is possible i would like to go this path yet retain a streetable duty with this car, this means road trips and crusing and in general just regular street stuff. would consider also taking it for a couple of runs down the 1/4 as well.
    can this be done or am i just wanting the impossible?
    WK Stato
    Oct 2008
    Quote Originally Posted by vtssII View Post
    few quick questions, are these setups street legal ? or are they a race only setup ? You would need an engineer to sign off the mods,has been done in Melbourne.
    i live in victoria if it helps. Thats nice
    im thinking of getting a twin turbo setup on a unopened ls1, and will just be pumping low boost( not going to be breaking shit, just want something out there) Sounds good.
    if i were to purchase such a kit, does it require much mods to the car to fit? I've done it and didnt have a problem , have heard others did run into problems, follow the instructions and call them for help if needed
    will i need a better cooling system ? No but will require mods,part of the kit
    injectors? Yes go 60lb
    will my auto be able to handle this power/ torque increase? or will it be a bit too much for it? its currently fitted with a shift kit, std converter. Tough question, my auto is 100% stock no cooler, never changed the oil 330kw's at the rears for about 2 years runs 11's heavy car, lucky, maybe............
    also will the diff be capable of holding in there okay? Not been an issue, drive shafts however
    if it is possible i would like to go this path yet retain a streetable duty with this car, this means road trips and crusing and in general just regular street stuff. would consider also taking it for a couple of runs down the 1/4 as well. Daily driver, wife uses it everyday. Clocked up at least 50thousnd kays
    Sounds reasonable to me....
    WHII Statesman
    Sep 2006
    Geelong, VIC
    You have next to no chance getting a turbo kit on a pre-VE engineered in VIC, from an emissions perspective.
    GEN-TT kits require a fair bit of hacking and bending to make fit, if you are keen on twins check out the ASE twin turbo kits instead. Otherwise, GenRacing and ASE make nice single turbo kits.
    If I had my time again I wouldn't go turbo. I still don't have the confidence to walk away from my car after a drive without checking if it is on fire...
    vt ss II 5.7
    Nov 2010
    B town
    why wouldnt this pass a engineers cert?
    will look into those other companies,
    is there anything i havent picked out which is required as a decent mod that will need to be done for this setup ?
    WHII Statesman
    Sep 2006
    Geelong, VIC
    vt ss II 5.7
    Nov 2010
    B town
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    vt ss II 5.7
    Nov 2010
    B town
    just another quick question
    are supercharged ls1s in the same dilemma as the turbo setups for street legal wise? ive seen a heap of different setups from the centrifugal style setups to the roots style which fit under the std turtle cover for max sleeperness
    vy ss commodore 5.7ltr
    Jul 2006
    just S/C it and get a black powder coated cooler, don't have to get anything to serious, if your worried about engineers certificates then put some extra coin aside from what iv heard they cost a bit to get the certificate, there's tones of cars out there that are s/c or turbo'd with out having engineer's certs, as long as your not stupid and your cars not sitting on the bump stops you'll be alright.
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    move to QLD bro.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
  1. [General] how to keep your ride street legal.
    By fitz_vt in forum Holden Commodore How-To's
    Last Post: 02-06-2011, 12:45 AM
  2. Fully Sick Street Legal
    By Happydaze in forum General
    Last Post: 17-11-2010, 01:40 PM
  3. Replies: 30
    Last Post: 31-03-2010, 08:33 PM
  4. Calder Park Legal Street Drags 04/10/09
    By jaisvz in forum The Pub
    Last Post: 06-12-2009, 04:48 PM
  5. Worlds fastest street legal car.
    By VL Berlina 5speed in forum The Pub
    Last Post: 30-08-2006, 11:00 PM
