Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Catch Cans
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Default Catch Cans
    Hey Guys
    Just wondering why I'm seeing alot of NA guys running catch cans - I understand about being needed for boost but why are they needed on an NA LS1 car?
    N E info would be great
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Have a read of this Corvette PCV Oil Catch Can
    Basically, the Lsx engines have a bad pvc system, and coat everything in the manifold in oil (can be a fair amount, ive seen one lad with puddles of oil in his) so putting the can on stops all that crap hot oily air mixing with the fresh cool clean air comming in and obviously keeps the manifold clean
    I deff noticed mine ran smoother and responsed better when putting it on my ve, after a week or so of driving ive got a teaspoon or 2 of oil in there
    Hope this helps
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    GM GEN3's Avatar
    GM GEN3 is offline GM GEN3
    legs ATM
    Sep 2008
    S.A
    I would be keen on a catch can where can you pick them uP from plus i plan on taking my car on the track one day i think you need one or you cant get out on track!
    vy ss commodore 5.7ltr
    Jul 2006
    You can get some good ones on ebay, have a look there, Elite Engineering catch can's look to be the goods from what iv heard.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Yeah ive got an Elite one, very good quality and havnt had any problems with it
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    +2 for elite. Excellent product, no dramas at all. I pick up a couple of teaspoons of oil after a week or so of driving.
    Definatley worth the money!
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by SAMO-87 View Post
    Yeah same, works very well
    VT SS S2 A4
    Aug 2005
    VX SS LS1
    Oct 2010
    Chinchilla Qld
    I am also keen to install one on my VX SS just a quick question should i buy one with a breather or one with out...and how hard are they to install
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    Another vote for Elite cans - they are the duck's guts.
    I'd buy one that is sealed - as the breather type ones do not comply with EPA rules and you may get pinched if you get pulled up.
    cheers
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    hmm might try one out, did you guys pull your manifolds off to clean them out when you put the catch can in or did you just put it in?
    Going where no late model stato/caprice has gone before.... GAME ON!!
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by walesy View Post
    I just wiped in as far as i could to clean the manifold, however mine was pretty much spotless anyway, i wiped the tb down the same way, was also pretty clean
    GM GEN3's Avatar
    legs ATM
    Sep 2008
    S.A
    Yeah I'm going to get one does any one have a picture of how it hooks up on to the ls1 motor i looked at some pic and a lot of them are different thanks
    VT SS Ls1
    Mar 2011
    Chirnside park vic
    How hard are these to put in??? What benefits would come from a catch can? How much would a shop generally charge to put one in??
  15. #15
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Heaps easy to put on, benifits = clean manifold and smoother running/responsive (read link at top of page) as for the ls1 setup someone on here will prob have one fitted so im sure they can help you out
  16. #16
    VH SS
    May 2009
    Toowoomba, Qld
    I realise my engine isn't an LS engine.
    But I found out on my first track day, that when I started the engine, after sitting in the pits following a track session, the engine would blow a heap of oil smoke out the exhaust for 20 seconds or so. Seems it had dragged a heap of oil into the intake. So before next track day I fitted up a catch can and there was no further oil burning problems. And it caught quite a bit of oil in the can, especially in the early couple of sessions where I was had it sitting above 6000rpm fairly regularly.
    Some advice I will offer you from my experience, is a lot of so called catch cans are simply an empty oil can with a couple of pipe fittings. They won't do a proper job of seperating the oil, because there is nothing inside to catch the oil. A proper catch can/oil seperator will have some sort of baffling inside to catch the oil before it gets sucked back into the engine. I ended up buying a catch can with nothing inside (because I couldn't find a proper one), pulled it apart, fit a piece of aluminium plate (with several holes drilled in it to allow airflow) inside dividing it into 2 halves (inlet side and outlet). Then stuffed some stainless steel wool into the inlet side so it would catch the oil. Worked a treat.
  17. #17
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Yep what he said ^ the elite however is very good qualtiy and has heaps of that steel wool looking stuff in the top part
  18. #18
    GM GEN3's Avatar
    legs ATM
    Sep 2008
    S.A
    Default catch can install
    is this how it goes i found this pic
    Attached Images Attached Images
  19. #19
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    ^^^ that is a vy on setup vt/vx LS1 have a different setup. Just thought i would let people know.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
  20. #20
    GM GEN3's Avatar
    legs ATM
    Sep 2008
    S.A
  21. #21
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Hey Gm gen3, dont have a pic but let me see if i can explian it . In the pic you posted.The oil/gases get sucked out of the valley an put back in the manifold. The vt/vx setup takes the oil/gases from the back of both rocker covers an then puts it back into the manifold. sorry if this dosent make sense but i tried editing the image you posted but it wouldnt let me upload it after i did.??? im no good with computers.
  22. #22
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    thats the same setup as mine, the crapy air from the manifold goes into the can then goes from to the can to the manifold with cool clean air
  23. #23
    GM GEN3's Avatar
    legs ATM
    Sep 2008
    S.A
    Quote Originally Posted by DLFHUB666 View Post
    Yeah mate thanks any info helps i just wanted a pic to be 100% sure I'm getting it right don't want to mess it up cheers guys
  24. #24
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    check out
    http://home.exetel.com.au/qldkev/pic..._catch_can.JPG
    The top one is what you are after.
    Basically just diconnect the hose from the manifold and route into the catch can, then the catch can back into the manifold.
    QldKev
  25. #25
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Kevs spot on. Top one is the vt/vx setup, bottom one is vy onwards.
  1. LS1 Oil Catch Cans
    By Bitumens Shadow in forum LSx Development and Modification
    Last Post: 12-08-2011, 10:52 PM
  2. Oil Catch Cans// Worth it??
    By impulsive in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-04-2011, 11:31 PM
  3. where to get paint spray cans filled?
    By lepht93 in forum Spray Painting and Panel Beating
    Last Post: 03-11-2010, 05:54 PM
  4. Respraying panels with spray cans
    By Ace_VP in forum Spray Painting and Panel Beating
    Last Post: 19-07-2010, 08:48 PM
  5. indicators flasher cans and led globes
    By hakhawk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 01:43 PM
