Results 1 to 6 of 6
Thread: chatter
    VT SS S2 LS1 FTW
    Feb 2007
    townsville
    Default chatter
    hey guys was just wondering if it was normaly to get chatter in the rear end when under heavy acceleration? (lossing traction) and also when it changes from first to second there is a big cluck (i think from the diff???) when flat footed. it has had a mafless tune so it does shift harder. but the clunking noises wernt there b4 the tune. i own a vt ss auto (gen3) BTW
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    diff bounce.
    Sometimes certain shock and spring combos can stop it, but doesnt work on every car. Apparently the harrop diff mount stops it too?
    clunk could be flogged out bushes or diff backlash
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VT SS S2 LS1 FTW
    Feb 2007
    townsville
    well im putting 3.91 diff gears in in the next few weeks so might get my mechanic to give it a going over while hes got it
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Sounds like it could be a bush as f**ked out or it could be axle tramp
    I went for the pedders diff mount over the harrop sports diff cover with mount as its 80 for the pedders and 500+ for harrop
    hopefully your mechanic is gonna make it nice and tight with those 3.9's
    VT SS S2 LS1 FTW
    Feb 2007
    townsville
    how much would you expect to pay to supply and install 3.91 diff gears? just got a quote form my local tuner and he said $1550 plus 90 to recalibrate the speedo -_- i was looking around the 1000 mark 1100tops
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    I think your tuner shouldn't be charging you extra for speedo calibration if he's tweeking your diff
    Ask a few tuners if they do the work inhouse or if they outsource - I asked a reputable company here in brissy and saved $100
    shop around ring a few diff specialists in townsville as $1500 is a fairly high rate
    also ask what work beside the gear change will they be doing eg. adding shims etc etc
    few tuners in townsville - might even be worth a drive to Cairns or Mackay for a cheaper rate
    Dynolink
    16 Civil Rd,
    Garbutt. QLD. 4814
    Phone: (07) 4755 0000
    dynolink@austarnet.com.au
    Townsville Mechanical Services
    2 O'keefe Court,
    Garbutt. QLD. 4814
    Ph: (07) 4779 1934
    Aitkenvale Auto & Dyno
    8 Fleming St,
    Aitkenvale. QLD. 4814
    Phone: (07) 4728 3382
    sales@auto-dyno.com.au
