Results 1 to 11 of 11
Thread: Installing OTR without MAFless tune?
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default Installing OTR without MAFless tune?
    What sort of bad things happen if you install a MAFless OTR onto a car that hasn't been tuned for it? I more or less want to just fit mine up before I go to the tuner.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Well your car will run like shit EDIT>> (limp home mode) << EDIT because it need's the maf to tell it airflow an what not, you can get OTR's that run the maf as i had one on my ss before i got a ramjet an mafles tune.
    EDIT: I just remembered the ramjet can be ordered to run a maf or mafless.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    Mar 2008
    I was more or less just wondering if my duspeed OTR could be put on before I go to he tuner that's all.
    So it'll run like shit, but it won't explode?
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    It wont run, your car requires air flow through the Maf as it is a vital sensor for the engine to operate.
    I found this out the other day. My car started then died within 2 seconds.
    Mar 2008
    Oh well thanks for clearing that up for me, looks like I'll leave it to those guys to fit. I'd just read that when the MAF is disconnected it goes into a limp mode using the MAP sensor to work things out - obviously this is wrong!
    VY SS Ute
    Jan 2011
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by one_and_only2004 View Post
    It should go into limp home mode, They did this so if the maf failed you could still get it to a safe place.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Aug 2004
    Quote Originally Posted by soop View Post
    excactly.
    It will still drive, and drive reasonably well.
    as above, mine did
    VS Stato l67
    Mar 2009
    Melb
    Different engine i know, but my l67 runs with no maf, just feels rough and the engine light comes on. I found this out when I forgot to plug it in one day.
    The only thing is I wouldnt give it a hard time in case it leans out
    Nov 2008
    Smithton, Tasmania.
    It wont lean out.
    The PCM will revert to a rich VE table and low advance. You'll just use a tonne of fuel and make no power.
  1. Who will do a mafless tune??????????
    By Blakvsexec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2011, 11:27 AM
  2. Mafless Tune to 95 or 98 RON
    By Mickyshazz in forum General
    Last Post: 15-01-2011, 10:42 PM
  3. fash tune or mafless tune
    By howler31 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2009, 08:34 PM
  4. mafless tune for v6
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-05-2009, 05:18 PM
  5. mafless tune or not?
    By Ripcell in forum LSx Development and Modification
    Last Post: 13-07-2008, 05:28 PM
