Results 1 to 14 of 14
Thread: Vy ss exhaust
    VY SS
    May 2011
    Auckland
    Default Vy ss exhaust
    Hey all
    My car currently has a standard exhaust through to the rear where somebody has assholed the rear muffler and replaced it with pipe. It sounds alright but I'd like to gain a bit of power.
    I can get the rage stuff at a really good price.
    Opinions on whether pacemaker extractors are worthwhile? The factory ones don't look great for flow. Also is it worth heatwrapping them to improve flow?
    Apparently the vy onwards don't like replacing the cats so then looking cat back there are 4 options (in the photos). Plus high flow cats are quite expensive.
    The catalog says I'll gain 21kw. Surely I'm not loosing 40kw down my drive train though? It's manual if that helps
    Sorry it's the wrong way around didn't think about it when I took the photo
    Taylor
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    You'd be surprised, A fella's VY SS II in town did 202rwkw before his tune.
    I suggest Tri-y headers, magnaflow cats, and a 2.5" twin exhaust - that'll make it fairly torquey down low.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY SS
    May 2011
    Auckland
    I was thinking that the pipe sizes didn't sound great.
    Single 3" is a bit small
    Twin 3" is a bit big?
    I was thinking of starting with headers and going from there....
    Or am I better to do it all at once?
    Mar 2008
    I did mine all at the one time purely because I didn't want to have to get under the car more than once.
    VY SS
    May 2011
    Auckland
    Fair enough. Looks pretty easy to do.
    Is it worth heatwrapping the extractors?
    Mar 2008
    It could be, I've noticed that under bonnet temperatures are fairly high these days. A heat shield might do the job though. I wrapped my last extractors on the V6 and it caused them to rust out.
    Hot House VY SS
    Jan 2010
    As an ex Kiwi I know that the Rage brand is OK, there tube bending facility is very good but not so sure about the mufflers they use.
    Like you say the design they make for the LS1 is a bit strange, either twin 3" which is too big for a std LS1 or twin 2.5" into single 3" which seems a bit small.
    If you just want sound then a catback will do the job. Headers and cats are prob close to 2k NZ, quite a lot of money for the gain you get..
    Unless you go for an Xforce system, the cheaper option would probably be a custom system. Depending on how loud you want it, you could not have the rear muffler similar to your setup now as the two middle and rear mufflers on together is fairly quiet with std headers and cats
    VY SS
    May 2011
    Auckland
    I can get the headers new for 520nzd. I'm pretty keen on those.
    Im mainly looking to gain a bit of power. It's already reasonably loud so don't really want it much louder.
    Rage high flow cat sections are 260 a side, not excessive but the guy rekons my ecu might complain about it.
    Rear section (cat back) was about 350, can't remember which of the 4 that was for though.
    The info they provide says I'll get the best gain out of the extractors, and they seem to be the ones you guys are using too
    Mar 2008
    I replaced my cats with 200cpi magnaflows - no error lights came up for me.
    VY SS
    May 2011
    Auckland
    Mint. Might do them section by section then. Old cats are worth some money too. I won't be doing too much engine work so twin 2.5inch sounds like the way to go if I just get the rear fabricated too.
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    There's only been problems with the ecu when changing to 4-1's headers because you have to have O2 sensor extensions although I haven't heard of any cars of late changing just the cats and getting a fault code
    Twin 3in is not too big for a 5.7
    And why don't you see how much to ceramic coat your headers its much better than heat wrap
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by one_and_only2004 View Post
    same here
    Mar 2008
    Quote Originally Posted by Munz View Post
    Twin 3" is overkill for a standard 5.7, I only have a twin 2.5" on my 6L. Ceramic coating is a better idea than heat wrapping though - I have seen oil soaked heat wrap catch on fire, I'm yet to see this with ceramic coated headers....
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    Diffilippo stainles extractors, stainless twin 3inch system FTW!
    YouTube - ‪Stainless LS1 exhuast‬‏
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
  1. [VIC] FS Monasro exhaust, vx ss exhaust, K&N filter, various Maf's LS1 turtle shell & more
    By SenatorMike in forum Parts And Other Items For Sale
    Last Post: 10-04-2011, 10:39 AM
  2. Steam coming out of exhaust, also notice liquid sitting in exhaust tip
    By v8s&2wheels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2010, 12:35 AM
  3. [VIC] Swap my sports exhaust for stock standard exhaust - vu ss - cat back
    By supachippy in forum Swap / Wanted to Buy / Trade
    Last Post: 21-06-2010, 12:05 PM
  4. [VIC] HSV R8 exhaust system -suits all Twin Exhaust VE Sedans
    By vol800 in forum Parts And Other Items For Sale
    Last Post: 13-01-2010, 05:37 PM
