Results 1 to 4 of 4
Thread: vz ss 6.0 L76
    VZ SS Thunder ute
    Apr 2011
    Default vz ss 6.0 L76
    so i have heard many different rumours about these engines (L76) not exactly a ls2, gen 4...
    I'm just wondering what specs this motor actually has?
    the head casting is 5364 i believe.
    i am in the midst of looking at mods for the car, already have a difilippo exhaust fitted, looking for cam and heads next, but many people say that the heads are fine for 300rwkw? not sure n the head specs compared to a cnc machined set or even if it is worth the cost for them to be machined or change over set? any info would be great...
    thanks
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Stick with the stockers mate, they'll do the job nicely. The only problem with l76 heads is the AFM gear is built into them and you have to have it removed when putting a decent sized cam.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VZ SS Thunder ute
    Apr 2011
    yeah i thought they would for what i want. 300rw for the daily driver is enough i guess.......
    has anyone seen summit racing.com? being a chev engine i thought this site was good source of parts without paying the $$$ like we do here.
    VE II SS UTe Cammed
    Oct 2011
    NSW
    Stock heads are fine, they easily handle 332rwkw on my L77 which is pretty much the same
