Does anyone know which one the tacho wire is on LS coils? I need the signal for my eboost.
Also, where's the best spot to pick up a vacuum reference for the BOV and wastegate?
Not sure about tacho wire but i would also like to know so i can wire my eboost up too. The best place i have found to use is at the back of the manifold next to the map sensor there is a pcv line that runs into the car with a little valve on it (think its for heater or ac). I have used this line for bov's and wastegates befor with out any dramas. Just be sure to T it in on the manifold side of the little valve because that valve is a one way valve.
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
Oh righto thanks. With your eboost make sure you run the solenoid off a pressure only feed (so before the throttle body)
