hey all
just wondering whos done the LS6 manifold swap
whats involved if its a straight swap and what needs to be done?? and what lil tricks to it are there??
as i would like to do it same time as my cam in the next few weeks
regards
Benji
If your ls1 is from a vx onwards it already has a ls6 manifold. If its from a vt it will have the old ls1 manifold. It's a easy job just take injectors and rails off throttle body off take manifold bolts out remove manifold and replace with new one. Be sure to check all the gaskets.
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
oh thats easy done then hahaha
yeh dont need to worry bout it then, thanks for the reply bud =)
What's the benefit of installing an LS6 inlet over a standard LS1 inlet???
Before you go and buy a LS6 manifold.... just check your part no# by looking at the middle of the manifold on the passenger side and look at the serial number.
LS1 prt #'s 12560688. & 12556333.
LS6 prt #'s 12573572, & 88894339
12561184 & 12561182
It only at $126 so why not.
Ronald Reagan (1986)
What kind of power gains in KW's would one expect from doing this mod/conversion?
Around 10rwkw. Ideally you'll want to get the tune touched up to suit.
sounds better if i was to get a cam package & do the manifold at the same time & then go get a tune.....
Or you could not put the LS6 one on, and consider a Victor Jr and 4BBL....
My 6.8L Nitrous Fed VT SS
(now with nekkid women - page 9)
Got my ls6 manifold from commwreck in sydney for $110 inc freight give them a call mate
Real cars don't power the front wheels, they lift them
