Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By njmartin
Thread: Cam and stall query
    Vz ss
    Feb 2012
    Default Cam and stall query
    Looking at putting a cam and stall into my vz ss, I already have otr with mafless tune and full exhaust but I'm looking at going with something like 224/224 114 cam with a 2800rpm stall, should that be alright in my car?
    Jan 2008
    NSW
    Small cams are for pussies.
    Go big or go home.
    Hmm i cant think of any more atm, but you get my drift.
    Vz ss
    Feb 2012
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    5.7 or 6L?
    Sometimes there's no point in going bigger as it's not always better. I cracked 325rwkw with a 218/233 cam.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    njmartin is offline Banned
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    Wk Caprice Series II
    Jan 2010
    I'm told with this setup You should be able to crack 300 rwkw
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    if its a 6l most likely, ls1, no.
    if you tell your tuner you want 300rwkw he will give you a dyno sheet that says you got 300rwkw.
    dyno's can easily be fudged, take it too the strip if you wanna know its capabilities
    Mar 2008
    Quote Originally Posted by njmartin View Post
    Righto buddy.
    njmartin that is a GIGANTIC cam - the 5k stall is justified.
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    go for a minimun 3k stall or 3500 and go for atleast a mid 23*'size cam
    ive got a 231/236 if i ever do a cam again it will be atleast mid 240's
    VX Calais 5.7L LS1
    Feb 2009
    Gold Coast
    you have to watch valves hitting the pistons in ls1's with massive cams and unless your doing heads aswell then no point in going huge. the ports in the stock ls1 heads cant flow much more than a 238/240 cam. a proven cam is 232/234 and a 3k stally. that is probably the most common of cams.
    Vz ss
    Feb 2012
    Thanks for all the replies guys, I got that cam (vcm) and stall (TCE) for just over $700 so I can't complain, I've got a patriot gold dual valve spring kit on the way too, I'll throw it all in and see how I go, I don't want anything to crazy as its my everyday car too
  1. Centre Bearing Bracket Query & Tailshaft Ends Query
    By Sojourner353 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2010, 07:48 PM
  2. vs v6 query
    By martyvscommy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2010, 11:29 PM
  3. !!Query!!
    By vpkingdragger in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2005, 02:42 PM
  4. VS S/C CAI Kit - Query
    By projectaero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2005, 01:11 PM
  5. query
    By trees in forum The Pub
    Last Post: 20-06-2005, 11:18 AM
