Results 1 to 11 of 11
Thread: l76 cam
    2006 VZ SS Thunder
    Sep 2011
    Karoonda sa
    Default l76 cam
    Anyone know how the lunati voodoo range cams go??
    VZ SS
    Jan 2011
    2006 VZ SS Thunder
    Sep 2011
    Karoonda sa
    VZ SS
    Jan 2011
    LT60534
    Suits LS1 & early LS2 with L92 heads high-lift
    Hydraulic roller (RPM range 2400-7000)
    Duration at .050¨ 235°/247° valve lift .651¨/651
    You need the cam to suit L92 heads. I got the high lift for when i boost the engine later
    2006 VZ SS Thunder
    Sep 2011
    Karoonda sa
    If u don't mind me asking, wat did the full kit inc did removal set u back n where did u order from?
    VZ SS
    Jan 2011
    It be around 2 grand when i order push rods. I ordered it through precision intl but i get a good discount because my work has an account with them. VCM do kits for 2300 i think and gm motorsport do a kit for 2500 but i don't think they use lunati cams but maby they will order in for you.
    Tell us how u get on?
    2006 VZ SS Thunder
    Sep 2011
    Karoonda sa
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by Harris View Post
    LT60534
    On another note, high lift isn't that important with boost - air is forced into the motor. Overlap is the enemy so I hope you chose wisely.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VZ SS
    Jan 2011
    Lunati think different here are 2 different cams by lunati. One to suit ls2 with supercharger and the other i got to suit l92 heads with hi lift.
    Suits LS1 & early LS2 NOS / Superchager
    Duration at .050¨ 235°/247° valve lift .651¨/651¨
    No different in numbers i no there's more to them but even on lunati website nothings different in these cams except the heads they use.
    But i still want to make sure its right if anyone's got different ideas from lunati
    WHII Statesman
    Sep 2006
    Geelong, VIC
    jakstas's Avatar
    jakstas is offline Auto Elec
    VT SS S2 M6
    Jul 2006
    Thats not true Nemisis. I think my 242/253 108LSA is substantially too small.
    I find its much easier to actually get in cars and drive/hear them mate. All the cams that have ever been ground will work for the LS motors. Some will make more peak power than others. Some will give you mid range, torque, economy blah blah blah.
    Get yourself near some cars that are modified similarly to what you think you may want, and be prepared to change your mind 100 times over the course of your modification process. Heck, I started my build with a snotty Gen TTr kit and a 224/230 114lsa cam. They never even made it into the engine bay...
    My 6.8L Nitrous Fed VT SS
    (now with nekkid women - page 9)
