Reaper
Tells it like it is.
- Aug 15, 2004
- 6,493
- 11,502
- 113
- Location
- SE Suburbs, Melbourne
- RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Hi all,
This is a bit of a saga but I'm fresh out of ideas so I hope you can help!
I have a late model LS1 VZ which till now has been great. The motor is 100% OEM stock and as far as I can tell has been looked after for all of it's life. My problems started a while back back and I'll try to summarize as follows:
Just sitting idling at the lights it broke a spring on one of the exhaust valves and of course it started running like a complete bag of crap. Inspecting the break shows a crack that had been there quite some time and it finally let go at around 190,000km. The motor has never been thrashed and serviced religiously - everything under the rocker covers was clean as a whistle. I replaced all of the valve springs and the car runs great (quieter and better than it ever has before) save 2 problems:
1. Cold start misfire for the first 10 min or so
2. Throwing P0171 and P0174 codes (always as a pair) during idle (eg sitting at traffic lights) or 0 throttle situations (braking usually at low speed - doesn't seem to happen ever above 30mph). This will happen even at normal operating temperatures. After the car is up to normal operating temp the idle will be perfect.
Things I have tried:
1. Cleaning the maf (no difference)
2. Replaced a broken exhaust manifold bolt (no exhaust leak but I dropped a spanner on it and broke the head off - another crack that had been there for quite some time)
3. Removed and replaced both my rocker covers checking the silicone 'o' ring for damage etc
4. Checked all vac pipes I can think of for cracks and splits etc (everything is in great condition on this car)
5. Sprayed aerostart (pressurised fuel in a can - great stuff) pretty much over the top of the motor (zero leaks found).
6. Performed a PCM idle reset procedure (Idle improved somewhat when cold - still throws codes as described above
7. Installed new 02 sensors - better but still throwing codes although more infrequently now.
8. Plugged in a Vac gauge which seems to read normal to me (see toob: https://www.youtube.com/watch?v=EkQq...ature=youtu.be). Not in the vid I ran the car up to 3000 and held it there. Vac went up and stayed at around 23(?) steady.
One interesting observation I noted was when I sprayed aerostart down the intake duct (down steam of the maf) it made zero difference to how the car runs. I would have expected the idle to increase. NFI what to make of that
I also noticed that unplugging the tube that runs from the rocker cover vent to intake makes no difference to the idle quality. I have inspected the hose and as far as I can tell it's fine.
A lot of people have suggested a vac leak but I'm near convinced that is not the answer because:
1. Visual inspection of all lines (there are not many on this motor) shows all to be fine and in great condition
2. Vac gauge reads normal. If there was a leak of any consequence I'd suggest it would jump around or read low.
Aaaaaaaaaaaanyway.... I'm out of ideas so help is appreciated.
