Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 141
Like Tree1Likes
Thread: LS1 Guide to Power Stage I
    OLS108's Avatar
    OLS108 is offline MR Helpful
    Stockish VX Berlina
    Mar 2005
    QLD
    Default LS1 Guide to Power Stage I
    MCAI-$20-30 Here is the Holden Part Numbers for the MCAI
    92102689 HOSE - AIR CLEANER SCOOP
    92102700 SEAL - AIR CLEANER SCOOP
    92096849 DUCT - AIR INLET TO AIR CLEANER
    can be completed in 30mins see MCAI thread for DIY.
    Good set of Tri Y extractors and twin 2 1/2" system $1100-1500 ( genie , Pacemaker, HM 101's, Difillpo, all good )
    Mafless Tune $400-1300
    Diff gears A4-3.7's or 3.9's if you don’t use the highway much. M6 -3.9's or 4.11's if you plan on Drag racing a fair bit.
    OTRCAI- An Over the Radiator Cold Air Induction system, Power Torque or Sureflow make Very good systems for LS1's are around $500-600
    this should see you with 220-240rwkw and a 12 second time slip.
    Wanna Go faster ???
    Stage II
    Auto should see you looking for a
    Stall converter- $1100-1400 (aka Torque converter ) a 2800 stally is the Perfect Stall for a Unopened Or baby Camed Car.
    Manual owners should be thinking of a Good
    Heavy Duty Clutch, as I Don’t own a Manual I can only go from reports But I am Told a textilla is the Best value and performance Clutch on the LS1 market.-$1200-1600??
    Also on the Manual Side a
    Rip Shifter is going to be on your shopping list, I’ve had a Crack at a Rip shifter By GM Motorsport and WOW they are the Best Shifter I have ever used... $400-500
    Cam and springs Upgrade, From all reports a 222/224/112 is the Perfect Street Cam and will suit your 2800 stally Down to a Tee and along with a set of 918 springs Should see the Power, Torque and overall Drivability Greatly Improve..
    As for things Like Ported Throttle Bodys and Underdrive Pullies these are in the Next lot of Bolt on Mods and In MY opinion Should only be Considered after the Above Mods have been completed or in the case of the UnderDrives, these could be fittted at the same time as the Cam.
    Last edited by OLS108; 05-08-2008 at 09:36 PM. Reason: i saw a spelling error, for the very first time, yay
    Lish's Avatar
    Lish is offline Shake That
    VX SS Commodore
    Oct 2005
    Bunbury WA
    Quote Originally Posted by OLS108
    there is proberly threads on this but im about to go to bed and cant be bothered looking. will do research on it morro butttttttttttttt....
    are tri Y's better than 4 into 1's? its just i always see tri y's with better advertising than the 4 into 1's and you mentioned it. what differance is there in the two? when i look at them the 4 into 1's look like they would push the air out better, without the air crashing into air like the tri y's look like they do. but i wouldnt have a clue hence my question.
    any help much appreciated.
    (POSTED BY MIKEVXSS)
    If I wanted to hear from an arsehole...I'd FART
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    For a bit more accurate pricing on exhausts down here in vic, a defilipo system will cost you around $2500 ,$1050 for headers, $380 for high flow cats(2 if you run dual system) custom cat back around $750.
    For those interested in cam, mafless tune etc, this is what you get from G & D Performance as quoted by Matt
    G&D cam only package with MAFLESS tune is $3990 (including - Mobil 1 10w/30 oil, genuine oil filter, sump oil passage realignment, Oil pump blueprint, New G&D spec Billet camshaft, Adjustable double row timing chain set, Comp valve springs, coolant and custom MAFLESS tuning)
    Difilippo 4-1 headers fitted $1060
    G&D "Metal cats" $385 each
    Difilippo M/S dual 2.5" cat back fitted $745
    These mods will give you around 270-300 RWKW depends on the cam really Match this setup with a stealth harrop blower, and your in business.
    PS: these quotes were given to me as a rough guide
    minux's Avatar
    Feb 2005
    OLS108's Avatar
    Stockish VX Berlina
    Mar 2005
    QLD
    Quote Originally Posted by Lish071
    I always tend to tend to recomend TRI Y's cause they are really made for unopened or small cam cars, they Give Low down Power where as the 4-1's offer more High range in Power. Some Tuners always recomend 4-1's even for a Bolt on car, for example i Know Dan from Chipmaster is a Fan of 4-1's over TRI y's. But on the other hand I have a Mate with a VT II GTS with a 383 stroker , cam , heads, and harrop 8 tb manifold and still has TRI Y's becuase they help to give Good Low to Mid Power range.
    I will Do another Write up between TRI Y's and 4into 1's in another Thread.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Feel like elabertaing on mail order tunes, MAF tunes, a good set of springs for a bolt on only LS1 for insurance, etc.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    ve ssv ute
    Feb 2006
    personally the v8 with pacemaker headers and a redback 2.5" cat back is fast enough for me
    VT2 Chev V8
    Jun 2005
    Default Plan of attack
    Hey OLS108 (or anyone else),
    Do you think $2500 can get me Tri-ys, edit and 3.9s anywhere in Brissy? At the moment I have only done the catback by Rob Bliss (2.5" Mandrel etc). I have an A4 VT. Also what order should I get the work done in, and will the extractors get rid of the annoying drone? I'm sitting in London at the moment just dying to get back to driving my V8!!!!!! Havent driven it since the 31st of January. 1 more week and I'll be back in Brissy..... Mind you the holidays have been great.
    minux's Avatar
    Feb 2005
    Quote Originally Posted by VT2VEight
    That will get you tune and headers no problem at all. If you want a bit extra high flow cats are a goer, about $350 each.
    VP Executive R-spec
    Jan 2005
    LS1's there's a couple in my town with nothing more than an exhaust and a home made tune and they run 8.2 on the 1/8th mile all day (works out to high 12's 1/4) and they aren't even light weight budget models
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by minux
    high flow cats $300 buks is better spent on traction,CAI,Plugs or top notch oil ie the Penrite Synthetic option
    Cheers.
    * RVN 355 *
    minux's Avatar
    Feb 2005
    Quote Originally Posted by subdue
    Not really, my stocky cat's were choking my engine once i had the head's and cam done, placed in the high flow's and it was an entirely a new car. It all depends on the application. I don't know any LS1 owner's who havent added high flow cat's when they have done full zorst.
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    My mate's just changed the whole exhaust on his VX SS, spent about $400 getting a Redback system put in..
    The car is a 6 speed and entirely stock, apart from the zorst..
    He's got about $1500 and wants to know what to do next.. He's thinkin tune, but I reckon change the air intake, headers or something before a tune..
    What you all reckon?
    Shounak
    Always Right
    My Ride
    VX 346 Calais International
    May 2006
    this is the route i am taking for my vx calais international (ls1 of course)
    mcai - 2 hole mod $25 - done
    twin 2.5 in system - cost me $300 2nd hand
    pacemaker triy's - $320 2nd hand
    open up cats - $50 - $100 - still to do
    Mafless mailorder - $600 - from chiptorque or pt engines - still to do
    Mafless pipe - $180
    so all up at a cost of $1525 aint bad for around 310 - 320 fwkw (as stated by chiptorque)
    so for budget and bang for buck that aint bad if u ask me
    the reason I am going mailorder is where i am living = no tuners
    cheers chris
  15. #15
    minux's Avatar
    Feb 2005
    Quote Originally Posted by Shounak
    Go tune and a set of second pacemakers/defilipo header's, $990 for a tune and airbox mod, 600 easily for header's, worry about OTR later.
    Tell him to call APS at frankston
    http://www.apsservicecentre.com.au/
  16. #16
    ls1berlina's Avatar
    ls1berlina is offline "mick"
    VX LS1
    May 2006
    brisbane, northside
    go see rob bliss for some genie hurricane extractors and x-pipes($770). then see power torque engines at brendale for the tune($1090) and diff gears($1200). Do you know if you have an lsd? i thought i did but i didn't... i put a factory lsd in when i did my diff gears($750).
    And yes, some extractors will get rid of that drone.
  17. #17
    minux's Avatar
    Feb 2005
    Quote Originally Posted by ls1berlina
    Why not just get exhaust and tuen done at PT?
  18. #18
    ls1berlina's Avatar
    VX LS1
    May 2006
    brisbane, northside
    guess you can.. when i took mine in to PT they asked me to have the exhaust done beforehand. I think they outsource there exhaust work anyhow.
  19. #19
    Shounak's Avatar
    Apr 2005
    Thanks for the advice fellas, but he's just f*cked up the whole front end of his car. A couple of days after the exhaust..
    He's probably gonna sell it and try to get a VY SS after this..
    Shounak
    Always Right
    My Ride
  20. #20
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Can I ask how did the car sound? How bad was the drone, if there was any?
    Yours Kindly,
    Jim
  21. #21
    Shounak's Avatar
    Apr 2005
    Quote Originally Posted by 2Fast2FuriousDude
    I wish I knew.. I was going to drive the car tomorrow, but now I can't..
    I'm a V6 driver, the stock GenIII exhaust rumble is awesome. I can only imagine what it'd be like with a zorst..
    I'll tell you in a week or so..
    Shounak
    Always Right
    My Ride
  22. #22
    minux's Avatar
    Feb 2005
    lol stock gen3 rumble? There is no rumble.
  23. #23
    May 2004
    I did my exhaust a while ago 2 1/2 twin cat back.... Droned abit until I put the Pacemaker headers on..... This made the sound alot deaper so it not as bad
    " Behold the turtle. He makes progress only when he sticks his neck out "
  24. #24
    91 VN SS 355
    Feb 2005
    WEST SUBS
    for a stock engine a cat wont do crap all, when u go spending thosands on internals etc... tune , edit whats $300 buks any way.
    Cheers.
    * RVN 355 *
  25. #25
    minux's Avatar
    Feb 2005
    If you say so, although i know many exhaust places and tuners who will say otherwise when it comes to gen3's
LinkBacks (?)
  1. 07-11-2011, 06:10 PM
  1. VT/VX RetroFit Guide for: VN/VP/VR/VS
    By azkwazere in forum Holden Commodore How-To's
    Last Post: Yesterday, 05:29 PM
  2. VR/VS Maintenance Guide
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 07:41 AM
  3. DIY tinting guide
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2006, 04:39 PM
  4. Price Guide....
    By luvmycommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 03:39 PM
  5. Stereo Guide
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2005, 02:20 PM
