Results 1 to 6 of 6
Thread: Ls1 Auto Shift Kit
    VU Spac 5.7
    May 2006
    Default Ls1 Auto Shift Kit
    Gday, is anyone able to help, I want to fit a shift kit to the auto in a VU LS1, do I fit the electronic module which increases line pressure and therefore firmer shifts or is there an effective alternative?
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    VU Spac 5.7
    May 2006
    OK thanks for the reply, but Ive had a tune done and the auto seems exactly the same as before (improved engine power though), Im really after an auto shift improvement and these modules only affect 1 thing the fluid pressure within the auto, also they have a switch so it can be switched on for firm shifts and off again to return to stock soft shifts. Really want to know if this is the way to go or is there a shift kit as in the old fashioned type which requires installation of different springs and valves etc that works better.
    Thanks again. VU-S-LS1.
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    All the shift parameters can be changed in the tune file. Obviously when you had the tune done they left the shift settings as stock or near to.
    Just increasing line pressure can cause other faults in the trans. Find a reputable tuner & get them to sort it for you.
    OLS108's Avatar
    OLS108 is offline MR Helpful
    Stockish VX Berlina
    Mar 2005
    QLD
    Quote Originally Posted by vt1538 View Post
    Great advice above
    Jun 2005
    SA
    the old shift kit designed was just to improve pressure thats all so its the same thing.
    if the tuner did the calibrations correctly, u should have noticed a fast difference.
    eg shift times for economy, and power mode.
    also transmission shift points should have been changed.
    pm me with more info, and ill see if i can help out.
  1. Shift Light for auto
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2010, 10:16 AM
  2. shift kit for auto
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 05:40 PM
  3. vn v8 auto stage 2 shift kit
    By griffindore in forum Parts And Other Items For Sale
    Last Post: 03-06-2006, 07:29 PM
  4. vt auto shift kits
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2005, 12:49 PM
  5. Vs Auto Shift Kit
    By 64now95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 07:30 PM
