Results 1 to 6 of 6
Thread: Squealing belts/pulleys
    Sep 2006
    Default Squealing belts/pulleys
    On cold morning or after prolonged storage when i start my car belts or pullys make a squealing sound really annoying and used to go away when warm but now is constant. However if i warm her up then shut it down then restart it it stops and is all good for the rest of the day until another cold morning. It sounds like it's coming from the A/C Compressor area. Does anyone have the same problem? Is it just belts need replaceing or is a pulley bearing on the way out? Is it difficult to replace the pulleys? Also the pulley without a nut do u have to replace the whole plate to replace it? Cheers. This is an LS1
    VN S1
    Jan 2008
    See if the outside of your belts are chewing up at all if it is you know somethings now right maybe a bearing.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Cheap fix can be some candle wax on the belts. Else replacing belts can make it go away if its not the compressor. How old are the belts?
    and 3 Dangerous non ABS VN's
    Sep 2006
    Sir VxSs's Avatar
    Sir VxSs is offline Its gotta B a GenIII !!!
    Vx Ss II 6SpD
    Aug 2007
    Western Suburbs MeLbOuRnE
    have the same prob to mate on my vx ss eactly how you described!! my belts look alrite ! im just gona chuck he in for a early service!! good luck
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Does the noise change or go away if you turn the air con on? It may be the clutch bearings on the compressor if that is the case.
    Visit my Facebook page
LinkBacks (?)
  1. 16-05-2008, 06:51 PM
  1. Squealing brakes.
    By 97 SEN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2010, 12:48 AM
  2. VS V6 Pulleys
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2008, 07:53 PM
  3. Engine Pulleys VS V6
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2006, 03:44 PM
  4. squealing commodore
    By 6 SLEEPER in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 07:48 PM
  5. Strange 'moaning/squealing' from rearend
    By smaddock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2006, 08:57 PM
