Results 1 to 7 of 7
Thread: Roller rockers
    2002 vx hsv
    Apr 2005
    Question Roller rockers
    Hi Holden fans, Dose anyone no kw gain i would get if 1.8:1 roller rockers were used on a 255 kw ls1 motor
    VX2 CALAIS V8
    Jun 2004
    S/E Melbourne
    Quote Originally Posted by Inch
    If you add higher ratio rockers it will change the lift of your cam and will change your power output, very hard to give a guestimate. I guess you know you need to change your springs as the stock one's will let go.
    If you know the spec's of your cam to work out the new lift you divide the lift by 1.7 and with the answer you times by new ratio to get the new lift
    i.e .559 / 1.7 = ~.329, you then take that lobe lift and multiply it by whatever rocker ratio you want. With SLP 1.85 rockers your new lift specs become .329 X 1.85 = ~ .609
    Your cam spec's may be the one below
    Manufacturer - Model----------Dur Int-Dur---Exh-Lift-- Int Lift Exh--LSA
    GM---body (2001 - 2002)......196......207....0.467.....0.479...........116.0
    with 1.80 ratio...........................................0.494......0.507
    with 1.85 ratio...........................................0.508....0.521
    Your better off changing the stock camshaft to a performance one and not worry about changing the roller rocker ratio.
    Here is a link to explain camshafts
    VX2 CALAIS LS1 - EFI DYNAMICS tune 13.24@105.41 with 219 rwkws stock gears
    2002 vx hsv
    Apr 2005
    Question
    Thanks for the info on the cams. Also not much info on 4" maf pipe for ls1,are thay as good as thay make out
    VX2 CALAIS V8
    Jun 2004
    S/E Melbourne
    yeh, there is but it's all relative to other changes, best thing to do before buying one is to mod your HSV CAI with a second hole then you will have more air getting into your airbox.
    2002 vx hsv
    Apr 2005
    Thumbs up
    THANKS, I have already put a second hole in and have a after market air filter,MAF pipe would be next ?. Dont no cost to get one to NZ.
    VX2 CALAIS V8
    Jun 2004
    S/E Melbourne
    Got to a local HSV dealer and give them the VX GTS Maf pipe part number 06M3990701 I think they around $160-$180AUD if you have no luck may be try the shop on the forum to see if they will separate from the MAF package here
    postage from AUS would be cheap the MAF pipe weights not very much at all.
    If you have no luck send me a PM and I'll steer you to other places.
    Keep away from ported MAF's from my experince the gain was is 5.5rwkws, I took the ported MAF off once I got edit and never looked back.
    2002 vx hsv
    Apr 2005
    Thumbs up
    Thanks for your input
  1. roller rockers in v6 3.8 VP-VS
    By jimrichards1964 in forum General
    Last Post: 23-09-2008, 10:02 PM
  2. YT 5.0lt Roller Rockers
    By AirStrike in forum Yella Terra
    Last Post: 04-03-2007, 06:58 PM
  3. roller rockers
    By blackgen3 in forum LSx Development and Modification
    Last Post: 29-01-2007, 04:11 PM
  4. what do roller rockers do ?
    By itchy pits in forum V6 Development And Modification
    Last Post: 30-10-2005, 06:31 PM
  5. roller rockers on vt
    By chevy_big_block_bro in forum V6 Development And Modification
    Last Post: 11-10-2005, 12:36 PM
