+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: Prep for Drag and Dyno
    JUZDVS's Avatar
    JUZDVS is offline 242.8rwkw JUZDVS Executive
    VY SS Ute
    Nov 2008
    North Shore, NZ
    Default Prep for Drag and Dyno
    I'm headin to the strip next friday and then a Dyno day the next day with my VY SS Ute (Auto) and I was wondering if there was any simple things I can do to improve perfomance.
    It had a service about 7,000k ago and I'm going to clean/replace the panel filter but is there anything else I should be having a look at?
    Any help will be appreciated
    Thanks
    Justin
    HRT 666's Avatar
    HRT 666 is offline Cammed 8t-body stroker HRT 666 Berlina
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    Do you still have the factory diff gears? as some 3.9's would help on the strip with the auto. Tyres? what will you be useing? If you had the spare cash some 90-10's in the front with stock fe2 in the rear would also be of great help. Maybe a new set of plugs also and run with at least half a tank of fuel at all times as the stock bucket inside the fuel tank doesnt like to get too low.
    Hope thats some help.
    Edit : dont forget to over fill your oil by 500mls also.
    and check all other fluids
    JUZDVS's Avatar
    VY SS Ute
    Nov 2008
    North Shore, NZ
    sweet thanks for the tips HRT666. Its still got the factory diffs, what do you mean 90-10's? Haven't heard of that term before I 'm guessing your talking about the suspension, its got super low kings front and rear. I will be running 245/35/r19 street tyres all round.
    Going to check the spark plugs and fluids now
    VT
    Apr 2005
    QLD
    Quote Originally Posted by JUZDVS View Post
    He's referring to the percentage of bound vs. rebound.
    They have the ability to extend very well, but are very firm on retraction, thus why they're used to keep the front 'up' and the weight over the rear wheels.
    http://www.koniracing.com/pdf/spa1.pdf
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner VYClubby Executive
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    Also put some octane booster in your fuel. Remove the air filter if it isn't the factory air box. And at the drags drop the rear tyre pressure to 25psi.
    SAV_117's Avatar
    SAV_117 is offline Donating Member SAV_117 Calais
    VY Lumina
    Jul 2008
    VT
    Apr 2005
    QLD
    After all the posts in this thread though, isn't that the reason you go to the strip? to try things and see how they have an effect on your time? try it as it sits, have a list of modifications that you can humanly do at the track (tyre pressures, weight distribution, intake and exhaust mods) see how you go from there and when you go home, then you can change your diff gears and whatever to see what you get next time.
    If you're serious about it, record what you can about when you run, air temp, humidity, track temp, weather situation (sunny, overcast)...if you were running slicks you would take the temp of those too after your tyre warmup.
    JUZDVS's Avatar
    VY SS Ute
    Nov 2008
    North Shore, NZ
    VYClubby's Avatar
    Nov 2006
    Quote Originally Posted by SAV_117 View Post
    why 25????
    I run the same size rims and tyres on my car, and I have found that 25psi works well for me.
    vy ss commodore 5.7ltr
    Jul 2006
    if you have the turtle shell on, you could remove it, apparently you get a little bit more out of them, bout 4 extra kw iv been told, not much but every bit counts, due to the heat they hold in under them, let that heat out and the engine runs a tad cooler creating a tad of extra power.
    JUZDVS's Avatar
    VY SS Ute
    Nov 2008
    North Shore, NZ
    Yea good idea it does get pretty damn hot under the cover. You could cook something under there I reckon.
    But would having the tray open cause a bit of drag as the air moves through it?
    VT
    Apr 2005
    QLD
    Drop the tailgate....or even better, take it off!
    JUZDVS's Avatar
    VY SS Ute
    Nov 2008
    North Shore, NZ
    LowVp's Avatar
    LowVp is offline VP nut LowVp Executive
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
  15. #15
    VT
    Apr 2005
    QLD
    I'm not to sure if I should take you seriously or not lol
    Mate, a LOT of people have that problem, you're not on your own there ha ha ha
  16. #16
    Jul 2006
    unless you've got a hard top on it already, then would be ok as long as its locked down properly
  17. #17
    VT
    Apr 2005
    QLD
    Quote Originally Posted by cpbait View Post
    that's even more weight again though. weight that will soak up time....
  18. #18
    JUZDVS's Avatar
    VY SS Ute
    Nov 2008
    North Shore, NZ
    Nah I just have the factory soft cover, prob weights about 5ks but every little bit counts I guess. What about taking out the spare wheel coz that must weigh a bit?
  19. #19
    VT
    Apr 2005
    QLD
    You're right, every little bit of weight adds up to make a whole lot.
    I would be dropping the tailgate off, dropping the spare and any other s.hit.
    Best thing is, if you find out you need a little more weight for the drags, you can put your spare back in....
  20. #20
    JUZDVS's Avatar
    VY SS Ute
    Nov 2008
    North Shore, NZ
    Thanks heaps for all the advice its much apreciated I will post my time up on the weekend sometime
  21. #21
    HRT 666's Avatar
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
  22. #22
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ VN_Luke W427 VN_Luke W427 VN_Luke W427
    VT, RB30EST VN
    Mar 2005
    I reckon just drag it as is - as you drive it on the street ....
    sure you can go chase a faster time etc, but if it's not as it's driven daily then it's not as cool!
  23. #23
    Jul 2006
    maybe drag at the lightest you can then put the spare in tailgate on and see what its like with your full everyday weight to see what the difference is. and get both times so you know on the street and future potential.
  24. #24
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400 POVRTY Executive
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    putting the tail gait down makes less wind resistance if you havnt a hard top, but also transferes more wait further to the rear of the ute resulting in better traction and a low "squat" in the ass end
  25. #25
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    I think mythbusters did a segment that tailgate down actually creates more resistance than tailgate up! - whether it makes any significant difference to the 1/4 times, I don't know.
    Fuel Economy Tip - Keep Your Tailgate Up | Daily Fuel Economy Tip
+ Reply to Thread
  1. Dyno Results, Drag Results, Circuit Results, comparo
    By impulsesv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-09-2008, 03:58 PM
  2. painting pushie, prep work?
    By pow3rslave in forum The Pub
    Last Post: 06-06-2008, 01:17 PM
  3. what prep is needed to paint my vp?
    By benjiaka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2007, 10:45 AM
  4. reco prep 4 turbo? 4 bextor..
    By i_want_kw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2005, 04:19 PM
  5. engine prep for forced induction
    By Matt H in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2005, 01:52 PM
