Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Like Tree1Likes
Thread: oil for ls1?
    vy ss commodore 5.7ltr
    Jul 2006
    Default oil for ls1?
    hey everyone, i know fully synthetic is recomended for the gen3, but was wondering is castrol magnatec 10w40 ok in the gen3?
    iv been useing castrol edge 5w30 and wanted to change to a slightly thicker oil, is the magnatec ok?
    i know magnatec is good oil, used to use it in rangerovers, jaguars, etc, but wanted to know if ok on a gen3.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    i am currently running 10w40 sofar so good, (mobile one)
    as it supposed to be summer.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Jul 2006
    oh nice, thats a full synthetic yeh the mobile 1, the magnatec as far as i know isn't i think its a semi synthetic, but would that be ok?
    VY 1 Maloo
    Feb 2006
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    I think my mechanics use a mobil semi-synthetic on mine, not sure what one though...
    Jul 2006
    oh ok, yeh was leaning towards the castrol edge 10w60, we used to use it at work till they switched to valvoline 10w60, but its too thin the valvoline, i got a price on the edge at $75 for a 5ltr and needing 2 as there only 5ltr containers, was useing edge 5-30, but want something a bit thicker as the kays are up in the 170k now.
    will get some after christmas.
    carless for now
    Feb 2007
    perth,Western Australia
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    Jul 2006
    yeh i used a 5w40, but its a bit rattly, defenatly going to switch to the 10w60 castrol edge
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    What would eveeryone recommend for an LS1 with 85,000kms on it?
    Most mechanics just say Mobil 1, but I was thinking Penrite Sin15.
    Cheers,
    Sam
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    I had recently put ULX 110 10w30 in the 6L and haven't found any problems so far, not cheap but from recent readings Mobil 1 isn't what it's cracked up to be and wanted to try something different to Castrol and the other so called flashy advertising brands.
    I decided to give ULX 110 a go after reading another oil thread on JC, you can grab it from Enhanced Automotive, it's not cheap but neither is replacing a engine.
    Oct 2003
    for starters mobil 1 synthetic is recommended on HSV's not holdens even though they are the same motors up to VZ anyway. go figure, holden uses various oils themselves including magnatec on holdens
    if the motor is noisy on the recommended then its probably valve train noise.
    i've run almost every oil, for mine pennzoil was quietest, also some others of a 40/50 grade when the oil was clean, noise returned as it got dirty again usually about 5,000K's.
    rebuilt the top end now using 5/30 Edge and its quite all the time, good oil pressure at 40 psi idle. may try 10 60 next to see the effect maybe ok for summer atm, was ok when the top end was noisy, but now its not. fixed the actual problem instead of hiding it with thicker oil.
    PS thicker oil will cause worn lifters to be noisier on startup, but quieter hot. thinner oil will flow faster into the lifters to pump them up sooner than thick oil less start noise, but will be noisier hot. bit of a juggle on worn parts to cover it up...
    Jul 2006
    yeh i was recently told by holden when i took it there to get my water pump done under warrenty that my engine noise is piston slap and gudgeon pin noise, they said its minor atm, thats why i posted bout strocker kits as a possible rebuild option down the track if it gets worse, but when i asked the advisor at holden what would he recomend to quieten it down a bit, what oil would be good, he said mobil 1, nothing else, thats what we use and recommend and no problems with it, i haven't tried mobil 1 in it yet, but like castrol from personal experiences with castrol in the trade, and with the 5/30 edge it quietened my motor noise down straight away with in 10-20 seconds of start up, but the noise is slowly getting worse even with a 5/40 in it, its a little quieter but not much and a constant ticking, but the start and drive rattle has gone with a selenia star 5/40 oil.
    Jul 2006
    drained the oil and put the castrol edge 10w60 in 2 weeks ago and its heaps better, quieter motor still a minor noise but 90-95% quieter and feels a bit tighter under acceleration, selenia star was good, but i think better suited to newer fresher motors, reved alot freer but was still noisy, quieter now and feels a bit tighter with the slightly thicker oil.
  15. #15
    VE 6.0
    Mar 2009
    Jul 2006
    yeh i use magnatec on all other cars i work on unless specified for a different oil from factory, like a full synthetic for a gen3, but heard magnatec is good for the gen3.
  17. #17
    1994 HSV CLUBSPORT NO.356
    Mar 2009
    wainuiomata new zealand
    Quote Originally Posted by cpbait View Post
    mate i wouldn't put magnatec in my lawnmower,that stuffs crap!!never heard so much rattly lifters on start up when using magnatec,funny that when switched to a different oil no rattly lifters on start up!!,whats that telling you!!the stuffs like water!!
  18. #18
    Jul 2006
    was using edge 10-60 and castrol magnatec towards the end and no problems so worked for me, motors apart at machine shop anyway getting a stroker kit put through it, but had no problems there.
  19. #19
    VX SS
    Jul 2005
    East of Melbourne
    Magnatec in my VX SS and runs very quiet been using it for the past 3 or 4 years without any issues. I get it serviced at a workshop that works on a lot of LS1's
    and they use a workshop grade Magnatec which is a 15w40 not the 10w40 that you buy from the retail outlets.
  20. #20
    Jul 2006
    yeh when i pulled my motor down was all clean, mind you i do my oil every 5,000-7,500km's, mines done just over 200,000km's and it looked like a motor that had done maybe 30,000km's it was that clean, but that might be cause i did it so often, but was a lot quieter on the castrol and i'll use it again in my new build, be it edge or magnatec.
    As people have said though, every engines different and like different things.
  21. #21
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
  22. #22
    2007 wm caprice
    Nov 2010
    cobar
    ill only use castrol edge 10w60 in my car. that advice comes from the owner of mainlube which make very very good oil but is very expensive and he knows this. through his research he found edge 10w60 to be the next best oil for the lsx motors bar none. its all to do with the film strength, as it is nearly twice as strong as its compeditors and this is where it reduces the engine wear. if you want a read jump onto the ls1 forum where mainlube is a sponsor and this info can be found
  23. #23
    VY SV8 5.7L
    May 2011
    Kadina,Yorke peninsula
    MAGNATEC IS HORRIBLE!!!! ive seen what it does to engines its litteraly like a magnet it sticks to everything. Ive done overhead cam replacements on cars that used magnatec and it was like one big rectangle of jelly sludge shit i had pull it all apart clean everything it filled up like a 1/4 of the bin with sludgy oil and he said oil pressure light was coming on you bet it was the ####ing oil so i have used Nulon #1 oil by far.
    COXYS VY SV8 (WORK IN PROGRESS)
  24. #24
    Vx ss
    May 2011
    Nsw
    Used magnatec once ages ago in my ls1 dumped it out after a week wasn't happy with it
  25. #25
    VX SS
    Jul 2005
    East of Melbourne
    Never had a problem with Magnatec, been using it in my VX SS for around the last 4 years, nice and quiet and from what I can see looking in the rocker cover it is spotlessly clean inside. I get my VX SS serviced by a workshop that specialises in LSI's and all the 6lt variants and they service heaps of them and they use Magnatec in all of them.
    It is the 15w40 workshop version not the 10w40 you buy retail. As a side note my daughter's Mazda 3 gets serviced by Mazda and they run the 15w40 version of Magnatec in all the Mazdas they look after. At the end of the day I guess it depends on how the car is driven and maintained.
