Page 1 of 11 12345 ... LastLast
Results 1 to 25 of 259
Like Tree10Likes
Thread: MACE Cold Air Intake
    VT 2
    Nov 2008
    Default MACE Cold Air Intake
    Ok So I finally got my act together on Saturday and spent some time putting the CAI from Mace in.
    Dead easy installation, as usual I didn't read the instructions. If Greg had included an Allen key, the kit could have been straight from IKEA.
    Things I learned from the job - Install the steel Pipe into the Pod filter first it's easiest that way. It's worth dropping the MAf off and giving it a quick blow clean.
    VT Commodores - we have it easy when it comes to making this box really perform. Between the radiator support Panel and the radiator itself is a plastic panel thats used as a spacer, and to locate the lower aircon gas return line. This panel covers a vent in the support panel that is about 4 inches long by an inch and a half wide. This vent if it's opened allows air to flow directly from in front of the radiator, to the head light surround area, where the CAI picks up from.
    Drop off the hoses from the radiator and drain your coolant. Lift the clips in the top of the radiator support panel. Lift out the radiator. Pull out the plastic panel. Cut the top half off, leaving bottom hose guide. Reverse process and vent is now open.
    If you have aircon (99% of us) the flow is obscured in part by the condensor.
    Tips and tricks - I used a nikko pen and marked the outline of the box on the panels around it. Then took the box out and put a strip of foam cushion tape on the marks. A little better sealing and a vit of vibration damping. I also sealed up the slots in the bends of thebox with some gaffa tape.
    The hole in the box for the 3" Diameter steel pod mount is a little oversize. I cut a piece of ice cream container lid out, cut a 3" dia hole in it (used mount pipe as a guide) slid it over the pipe, mounted everything up, then gaffa taped it in place to limit air flow loss. Theoretically speaking, this is not necessary, as there is more air going into the box than the engine can use, I'm just a freak for fiddling with things.
    Sounds good, it's actually quieter than what I had before which was a bare pod in the bay. I can hear the exhaust burble over the intake hiss now with the window down. Cool.
    Is there any effect yet on performance or economy ? Yes and No - Haven't run any times, and have been playing with chipsets so nothing specific. When I have something bankable I'll post it up. So do I have any non bankable feelings I want to post about it ? Yes. I think the torque curve is a little broader. I notice when I sink the slipper from low speed that the nose comes up - and stays up. Before the nose would come up then ease off a little when the torque converter locked up and stopped multplying torque. That sort of dead spot between about 1800 and 3500 RPM where not much happened seems a bit less apparent. Do NOT assume that this was all the doings of the CAI though, I'm playing with other bits and pieces as well.
    All in all, this is a damn neat install, dead simple, without adding complexity over the serpentine belt system (which I don't like - I had to change a serpentine on the side of the road once.....). Theres plenty of flexibility in the Intake hose extensions, the Pod does it's job, and I'm convinced that theres a heap of air hitting the box when your moving.
    Have fun.
    Andrew
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    VT 2
    Nov 2008
    I was on a time limit so I didn't take any during. Will put up a couple of afters.
    VT 2
    Nov 2008
    Im at work, so don't ask me to take the lid off. maybe on the weekend
    Attached Images Attached Images
    Mar 2008
    Once again thanks for taking the time out to writeup a very informative review
    I like how you’ve gone about tweaking the product to your requirements to make an even better installation, which we certainly encourage with all of our products
    On this note if you have a quick look at the fitting instructions you may consider doing things differently in this regard
    http://www.maceengineering.com.au/CA...STALLATION.pdf
    All in all another top effort
    Steve
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    MACE cold air boxes are endorsed by me for use with ANY Raptor Supercharger sytem on a Commodore VS - VY
    If you are a Raptor owner and reading this then be sure to tell Steve specifically that you have a R system and want a cold air system to suit, he knows the deal!
    Customers who have them already report a HUGE improvement in low end engine response
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
    Mar 2008
    Quote Originally Posted by Raptorsc View Post
    We've come up with a prototype box to suit the VT-VY Raptor R kits, of which we might manufacture if we get enough interest for people Otherwise you can modify our standard VT-VY box to fit. The earlier VN-VS boxes fit without any mods to the box
    Steve
    Mar 2008
    Quote Originally Posted by MACE View Post
    Steve
    Hi Steve.
    What sort of $$$ are we looking at for a VY Raptor box?
    Mar 2008
    Quote Originally Posted by hail storm View Post
    Hi Steve.
    If we get 10 people after the box we'll be able to make them and sell them for $250. Otherwise you have to modify our normal VT-VY box to suit.
    Steve
    LM8185's Avatar
    LM8185 is offline 183.4rwkw Ecotec V6
    VS Executive
    Oct 2007
    Wollongong
    Steve
    I have VS Ecotec with a Raptor R Blower installed and the MACE CAI too. You are right in the fact that the CAI did not NEED any modifying to fit it, but i did need to alter the intake pipe slightly to make it fit in conjunction with it.
    I believe that other forum members also neeeded to make minor alterations to the piepwork, but these were very minimum and cost effective.
    That said however, i did slightly altered my CAI so it would be neat and easy to alter the Raptor Intake pipework. The MAF meter is now situated flush against the CAI and runs into the box, with the Pod attaching directly to the MAF inside, making it neat, and much easier to make the alterations to the Raptor Intake Pipe to suit it.
    calebsnodgrass is offline Not defected... yet
    VR Commodore Executive, Series I, 3.8L
    Mar 2009
    Kadina
    hey guys,
    im not vey technical with the motors and how a CAI really works
    if someone can easily tell me how it works and any performance improvements..
    tks in advance
    Mar 2008
    Quote Originally Posted by LM8185 View Post
    Looks great though
    Quote Originally Posted by calebsnodgrass View Post
    hey guys,
    tks in advance
    As for how CAI's work, a detailed description can be found here.
    Cold air intake - Wikipedia, the free encyclopedia
    Steve
    Mar 2009
    Kadina
    thanks that link helped..
    one more question, would it improve engine power and economy even though my car is a stock commodore vr '93 series 1
    i dont have turbo etc
    just wonderin
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    hey guys,
    tks in advance
    Welcome to the site. I encourage you to hit the 'search button' and type in key words to find out information about CAI and many other questions that you may have. Alot of new users to this site immediately post and don't realise that alot of simple and complex questions have had threads sometimes multiple threads already posted with all the answers to their questions.
    Also, if you are very new to the car scene or you don't know the basics eg CAI, then I suggest going to a search engine like google and type in your required information. We all were very green on cars and not technical at one time in our lives, but instead of someone explaining the basics, there are many pages of info out there that will help you get started.
    For the record, CAI stands for Cold Air Induction. This refers to the vehicle getting cooler air to feed the engine instead of sucking hot air from within the engine bay or from within the factory restrictive airbox. Cold air has the benefit of making the car more efficient and increasing power sometimes only marginally in different circumstances. The colder air is more dense than hot air and this is what an engine loves to breath. Depending on the vehicle, gains from doing this modification vary. There are definetely no negatives to giving the car cooler air to breath
    Welcome again.
  15. #15
    Mar 2008
    just wonderin
    Yes it will
    Quote Originally Posted by HoldenOnn View Post
    Welcome again.
    Nice CAI writeup HoldenOnn As for research, there is a heap of info on here and on other sites but we're also happy to answer your questions
    Steve
  16. #16
    RALLIART Magna
    Krabbyball Champion!
    Sep 2008
    Cairns
    Installed my MACE CAI enclosed pod yesterday (VR V6) and i must say i am very happy with it!!
    Installation is very easy and it really is a perfect fit.
    Things i have noticed --- I believe this cai has eleviated some of the drone i get at 2500rpm.... the exhaust note sounds crisper with more of a burble at 2500rpm rather than a whooooop drone. Acceleration feels smoother.
    Can't really say if there is a power increase but the car does seem to climb the revs smoother than before.
    Induction sound is noticable but in no way is it overwhelming.
    I am yet to install the 70mm T/B i bought as well.... will be doing that over the weekend, so will post up how all that goes and hopefully wont have any issues with idle ect.
    Overall i think this set-up has made a nice change to how the car feels to drive and am very happy with the product.
    EDIT- Just thought that i would add that after a couple of days of driving it is clear that the throttle response has improved dramatically --- i am yet to put on the T/B.... i am thinking the throttle response will be very touchy when i do.
    The car feels to me that it has gained some power ..... it feels much lighter to drive with increased acceleration.
    I defiantly think that it performs better than the s/c vs cai i had on previously ....
    I dont know why so many people knock the pod filter .... with it enclosed i think the mod is really worth it. Anyway, i am enjoying driving my car again.
  17. #17
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    One thing I would like to know is if the intakes are legal in NSW? I would hate to be taking it off every rego time and then putting it back on again when its all passed.
  18. #18
    Mar 2008
    Quote Originally Posted by FirstVR_JC View Post
    Glad to hear your happy with the item FirstVR_JC
    Quote Originally Posted by Danoz View Post
    Given that the pods we use are an oil less item they should be considered legal, provided you have no other inlet mods. In saying this though to revert back to standard would take between 15-30min, which would be a good opportunity to clean the filter anyways
  19. #19
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    im gonna get one of these for my vz executive, will i notice a change in induction sound? will it b nicer then having just a pod filter
  20. #20
    Mar 2008
    Quote Originally Posted by henrytad View Post
    You certainly will, more so if you have a larger exhaust system fitted It's much more effective then just a pod filter as it block of engine heat and channels cool air direct to the filter
    Steve
  21. #21
    Jun 2009
    Castle Hill, Sydney
    installed the mace CAI kit on my commodore executive vz. after starting the car, the car struggles to stay on n keeps reving up n down n eventually turns off and displays the message "check power train". has this happened to anyone else? if so, how did you resolve it?
  22. #22
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    did you forget to plug anything back in?
    Body by Holden, Soul by Brock
    the Legend will live forever
  23. #23
    Jun 2009
    Castle Hill, Sydney
    nah everythings fine just the way it should be. cars still struggling. apparently no one else is having this problem except me :S
  24. #24
    Jun 2009
    Castle Hill, Sydney
    hey again guys, just tried disconnecting the battery, left it for two mins to reset the computer and it works fine. errors gone and the car isnt struggling anymore. cheers and thanks, and hope itll b a help to anyone else who gets the same problem
  25. #25
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Well thats random. Putting a CAI on the car shouldn't mess with the ECU.
    Ronald Reagan (1986)
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. Installing Mace air intake manifold insulator
    By EnFoRcEr_001 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2009, 03:46 PM
  3. cold air intake mace engineering v6 vy
    By imartinoski in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-01-2009, 12:47 PM
  4. [SA] cold air intake
    By vr-man in forum Parts And Other Items For Sale
    Last Post: 05-01-2009, 08:45 PM
  5. Cold air intake
    By damo1h in forum LSx Development and Modification
    Last Post: 21-12-2008, 12:02 PM
