Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 182
Like Tree5Likes
Thread: 1.9:1 ratio rockers to suit Buick (non ecotec) V6's
  1. #101
    VYII calais
    Jan 2009
    Anthony tight on money atm
    At least Mace have responded back to you. Good luck with them at that cheap price
  2. #102
    Mar 2008
    Quote Originally Posted by hsvanthony View Post
    put me down for a set if you could get your bank details to me via pm or something? and how much extra for postage, does this come with everything i need to just take old ones off and replace them apart from the value springs of course? should i pay first then wait for mailing very keen to get these in the car asap lol thanks steve
    Hey hsvanthony,
    In regards to your questions/statements...
    "Put me down for a set if you could get your bank details to me via pm or something?"
    Done
    "and how much extra for postage"
    Postage for these is usually $22 depending on the state
    "does this come with everything i need to just take old ones off and replace them apart from the value springs of course?"
    Correct
    "should i pay first then wait for mailing very keen to get these in the car asap lol thanks steve"
    We require payment up front before we mail off the rockers, which are sent via registered post.
    If you have any more questions please don't hesitate to ask.
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    ***Product Knowledgebase***
    Find us on Facebook:
    MaceEngineering
  3. #103
    VN Wagz's Avatar
    VN Wagz is offline PshhhhHHT- **TuTuTuTu**
    VN Berlina V6 Wagon
    Sep 2008
    Dunlop (North Canberra)
    these are gonna be good fun with some boost thrown into the mix!!!!
    I'd say us turbo guys are going to be getting a fair bit more power than the 10rwkW, as the snails are just going to compensate for the extra airflow by spinning harder to make the same manifold pressure... yay for turbos
  4. #104
    LX Torana-Hatch
    Jun 2006
    Yeah I was reading somewhere on here most people get about 3 times the extra power if the car is blown or turboed. i.e 30-45 extra rwKw
  5. #105
    Mar 2008
  6. #106
    vr acclaim 3.8ltr
    Sep 2008
    victoria
    Mar 2008
    All the rockers which have been paid for have been sent out today (with the exception of one NZ order). This leave 2 spots remaining.
    Steve
    MaceEngineering
  8. #108
    VN S2 LE 5SPD 3.8
    Mar 2010
    ive installed these today, which was a straightforward job
    buick engine seems sweeter, more willing to rev
    still need to get cat back exhaust currently got extractors 2.5 sports cat, but 2 1\4 whisper quiet system
    also got cai and memcal (do memcals actually work?) i noticed no difference
    also a lpg vehicle (suck through type, very restrictive diameter intake) i took this off and noticed a big performance difference on petrol
    im hoping for a bit more from the exhaust still
    overall i think its a very well engineered product and is worth doing at that price for surehowever with any motor performance upgrade its all about the sum of its parts, no one thing gives massive gains, everything has to be done to work together (synergy?)
    im curious to hear about other peoples results from the rockers
    regard
  9. #109
    Mar 2008
    Quote Originally Posted by vnmanual View Post
    regard
    Hey vnmanual,
    Glad to hear you're happy with the item You'll find that a cat back exhaust system will certainly make a noticeable difference given your current mods. Another thing to consider would be to remove the bell mouth installed in the manifold. This will certainly help to gain a few ponies top end.
    Steve
    MaceEngineering
  10. #110
    vr acclaim 3.8ltr
    Sep 2008
    victoria
    gonna put mine in this week just gonna check that everythings right and then should be installed by the end of the week ill let use know how i go
    btw i cant remember what my car was like without the chip is it worth having in? :S and if i take my bellmouth out will this help or just fk the motor in the long run for stuff all increase as if read here n there? thanks
  11. #111
    LX Torana-Hatch
    Jun 2006
    I have fitted mine up, engine revs out much better. I changed the oil with 10W40 Magnatec and I think the rockers (maybe lifters) are making a tapping noise.
    Should I use a thicker oil?
    Any suggestions?
  12. #112
    Mar 2008
    Depends on who you got the chip from as the rockers will lean the mixtures out a little top end.
    I think you’ll find with the rockers, removing the bell mouth will genuinely help given that it’s now the more prominent restriction in the inlet manifold. The car will idle a rougher though. If you have a little time up your sleeve you can try testing the difference yourself. If you’re not happy with the removal put it back in.
    Quote Originally Posted by LX_HATCH View Post
    Any suggestions?
    Glad to her she's got more go now
    Assuming everything has been installed correctly, that oil is definitely on the thin side. I would recommend, at the very least, sticking with the factory grade 20W50 oil if not a little thicker (depending on how many k’s the engine has done). This is regardless of the ticking noise (though it would be contributing to it) as the thinner film of oil would not offer as good as protection as the thicker stuff considering the engine was designed to run on thicker oil.
    If the engine was rebuilt with tighter clearances then it would be fine to run the thinner stuff.
    The increase in valve train noise could also be attributed to the stiffer valve springs you’ve installed on your engine, but without having heard the noise it’s hard to say.
    Please keep us posted
    Steve
    MaceEngineering
  13. #113
    LX Torana-Hatch
    Jun 2006
    Yes im preety sure I have installed everything correctly. I will monitor it once its driveable, im having some clutch dramas atm, and get back to you maybe even with a video.
    The engine has been factory spec rebuilt 5000km ago.
  14. #114
    Mar 2008
    Steve
    MaceEngineering
  15. #115
    vn calais
    Dec 2006
    PM SENT
    Damn i hope im not too late. is there still two spots left or have i missed out.
    if not im deffinently down for 1.
    359rwhp VN V6 Turbo Calais
  16. #116
    LX Torana-Hatch
    Jun 2006
    I found the problem with the noise.
    The pushrod end of the rockers were slightly hitting the KillKenny rocker covers.
    Untitled Document
    I slightly adjusted the rocker cover and its clearing for now
    Mar 2008
    Quote Originally Posted by Calais_5sp View Post
    PM SENT
    Sorry Calais_5sp all gone at that price
    Untitled Document
    Ah glad to hear it's all sorted
    I'll make a note of this when we do the ads on our site.
    Steve
    MaceEngineering
  18. #118
    LX Torana-Hatch
    Jun 2006
    Took it for a good drive this arvo and the noise has come back, the rockers are only just touching and it only occurs when the engine gets up to temp.
    Im going to take the rocker covers off, mark where the roller rocker tip is and then die grind off some of the aluminium on the rocker cover for clearance. The covers are about 3mm thick so there is plenty of meat available
    Will keep you posted.
  19. #119
    Mar 2008
    Any news?
    BTW how do you find the gaskets that come with the the KillKenny rocker covers?
    Steve
    MaceEngineering
  20. #120
    VX S S/C & BA XR6T
    Feb 2009
    If you run two cork /rubber gaskets it will give you the clearance needed,had the same issue on my car.All you need to do is get some bolts 3mm longer for rocker covers.Another option is to get rocker cover spacers but will obviouslly be a little dearer,about 60$ a pair from memory.
  21. #121
    LX Torana-Hatch
    Jun 2006
    Its not hitting on the top but hitting on the injector side of the rocker cover. I die grinded some off yesterday but didn't get it all fitted back up.
    As for gaskets I called a local autobarn and they are going to get back to me today.
    Karlos what car did you have the issues on?
    What rockers were causing the issue?
  22. #122
    VX S S/C & BA XR6T
    Feb 2009
    My old VS,FIT rockers and these covers.Was not heard of before apparently.
    Killkennys used to hit on my 308 aswell with yellaterras,same fix.Killkenny Castings have bad batches from time to time with everything.
  23. #123
    LX Torana-Hatch
    Jun 2006
    Yeah they are still hitting, and yes there is a slight mark on the top of the rocker cover, so I will be getting a new set of gaskets and doubling them up as well as giving the injector side a good grind.
    DO any of the big auto stores stock them?
    Autobarn were meant to ring me back today and didn't bloody call!
    What about spacers?
  24. #124
    LX Torana-Hatch
    Jun 2006
    Got some more info.
    Autobarn can get the gaskets (~3mm) for $25 each. I called a local gasket place and they can supply me a 1200x700 x 6.4mm sheet of cork gasket, so I will be purchasing a sheet and cutting my own gaskets.
    I will have heaps left over so if anyone else needs 6.4mm cork gasket for Killkenny rocker covers I will be able to make them up.
    Autobarn can also supply rocker cover spacers for $90 a pair.
    Hopefully I will get the covers fitted tonight with the thicker gasket.
    Ryan
  25. #125
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Sounds like you are on a winner there Ryan.
    Good Luck.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  1. Formula holden buick based v6's
    By mws in forum V6 Development And Modification
    Last Post: 15-08-2009, 07:52 PM
  2. Need pictures of buick and ecotec rockers
    By dons vs in forum Yella Terra
    Last Post: 09-06-2009, 12:23 PM
  3. buick v6 increase compression ratio?
    By VRV6BT1 in forum V6 Development And Modification
    Last Post: 04-11-2008, 05:09 AM
  4. rockers and pushrods to suit v6 ecotec
    By djeyecon in forum Yella Terra
    Last Post: 10-04-2008, 06:18 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
