Just though I'd give people a progress report on this product development.
Well they've been on my daily for quite some time now work quite well to say the least
Making the mid to top end much more usable, revving out to redline much more freely then before.
Hoping to organise some before and after runs over the next few weeks. Will keep all posted
Steve
The expected power increase will be similar to that of the ecotec rockers of over 10kw at the rears.
No tune is required with this product.
The price will be around the $550 mark which will include pushrods.
They're also the lightest rocker for this engine on the market and will work on all non ecotec V6's (including series 1 VN's)![]()
can't wait Steve. should go real well in the s1 with the extra lift they already have![]()
Body by Holden, Soul by Brock
the Legend will live forever
i'm keen, what else do you need to change to put these in?
so, do you specify what motor you have when getting these? since s1 vn use 3/8 rocker bolts, and s2 on use 5/16(or something to that effect, cant remember specific sizes or model change, but i know theres 2 different thread sizes on pre ecotec motors)
these are just modified ecotec rockers i assume(looking at their shape)? changed spacings to suit pre ecotec. good to see another option for pre ecotec motors!!
It certainly does, as I have a S1 myself
They don't hit the rocker covers, nor do they require spacers for them to be used as they comfortably sit under the factory rocker covers
Everything needed comes in the kit
That's correct hakhawk, all the customers need to do is specify what engine series they have and we'll send out the appropriate rockers to suit.
The rockers are based off LS1 rockers which are even lighter then the ecotec items![]()
when can I order?
They should be be available in about a months time when we get some stock up, but will be worth the wait![]()
i soooooooooooo cant wait, ima buy some within the week, got extractors, 2 1/2 exhaust and twin throttle bodys so this should set it off
Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
As for the rockers we'll have these in stock in about a 3-4 weeks
Steve
Hi, just getting "inline" here for my order too...
Cheers Daza.
would you use these with/without cams? or either or?![]()
you can use the 1.9's with a stock cam and heads as you are fairly close to max lift that the stock heads can hadle. if you modify the heads to handle extra lift then you can use these with a cam.
see post below for some numbers with regards to valve lift
here is a copy of a post from the V6 performance thread with regards to high ratio rockers (and the seed that started the journey to this product). hopefully this will answer a few questions people may have with regards to these rockers on the buick engines
for anybody with a s1 VN, you can see that with these 1.9:1 rockers on your engine you will have greater valve lift then the ecotec guys with 1.98:1 rockersas Steve has already mentioned, this gives the s1 engine the ability to breathe higher in the RPM band where these engines have previously been rather asthmatic and run out of steam before 5000rpm.
added benefits include the rocker fulcrum with roller bearing which reduces valve train friction and is good to help it rev harder and the parabolic tip used with these style of rockers greatly reduce valve guide wear that is evident with standard type rocker that tends to put a greater side load on the valve stem.
Sweet thing hey, looking forward to the power tests on these, those S1s can do with something like this, especially for supercharging!
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
friggen sweet, so ill get these. and should I decide to get cams at a later date it will be compatible. just what I wanted to know thanks![]()
so this can all be done in an afternoons work without removal of the heads? any special tools required or new parts recommended while the rockers are off? doesn't need new valve springs?
regards
so can we order them yet?
