Results 1 to 6 of 6
Thread: Raptor supercharged cam.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default Raptor supercharged cam.
    Is there a massive power increase from changing the cam in an ecotec to a performance supercharged suited one? I really don't want to reduce driveability and i have 1.8 Yella terra rockers.
    Does Mace have anything that would suit my setup?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Probably, why don't you give them a call tomorrow. I found Steve to be quite helpful.
    Ronald Reagan (1986)
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by acarmody View Post
    +1 to steve being a great help
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Mar 2008
    Quote Originally Posted by one_and_only2004 View Post
    "Is there a massive power increase from changing the cam in an ecotec to a performance supercharged suited one?"
    Yes there is a massive power increase
    "I really don't want to reduce driveability and i have 1.8 Yella terra rockers. Does Mace have anything that would suit my setup?"
    Unless your planning on revving your engine to the heavens, or planning on running heaps of boost without an intercooler, then the design of a FI cam should improve driveability not take away from it, giving you more power, better part throttle accleration etc. We do have a couple of grinds which would work well as shown in the link below
    COMP Cams to suit Holden Supercharged V6 - MACE ENGINEERING GROUP
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    Mar 2008
    Thanks for that Steve, The power increase seems pretty substantial!
    I'm looking at running 9psi non intercooled for maybe a month, then I'll be upgrading to 12psi with an A2A intercooler setup. By the looks of that I'd be looking at stage one wouldn't I, keeping in mind my rockers are already raising valve lift?
    I'm not really interested in raising the limiter either - I'm not one to rev the bejesus out of my ute.
    I'm also interested as to how much of a difference the 25mm manifold insulators have on supercharged setups - i'm guessing they're quite effective? I do have a Strut brace which limits me to either the Manifold spacer or the plenum spacer, not both, so which one would you suggest?
    Mar 2008
    “Thanks for that Steve, The power increase seems pretty substantial!
    I'm looking at running 9psi non intercooled for maybe a month, then I'll be upgrading to 12psi with an A2A intercooler setup. By the looks of that I'd be looking at stage one wouldn't I, keeping in mind my rockers are already raising valve lift?”
    With either of those cams you’ll have to revert back to standard ratio rockers unless you’re planning on machining down the guides. In saying this though you’ll be happy with either of those cams and stock rockers
    “I'm not really interested in raising the limiter either - I'm not one to rev the bejesus out of my ute.”
    The stage 1 or 2 cam would be the way to go.
    “I'm also interested as to how much of a difference the 25mm manifold insulators have on supercharged setups - i'm guessing they're quite effective? I do have a Strut brace which limits me to either the Manifold spacer or the plenum spacer, not both, so which one would you suggest?”
    If you had an NA car then I would go straight for the 25mm manifold insulator, however because you’re running boost the plenum spacer would be cheap insurance at preventing any cylinder leans outs through improving air distributions between cylinders. So I would go the 12mm plenum spacer and 12mm manifold insulator.
    MaceEngineering
  1. VZ SV6 - Raptor Supercharged
    By impulsesv6 in forum Raptor Superchargers
    Last Post: 19-03-2012, 08:21 PM
  2. Raptor V vs Raptor V Hybrid
    By apoc585 in forum Raptor Superchargers
    Last Post: 18-11-2010, 07:12 PM
  3. differences between vs supercharged and non supercharged engine harnesses
    By jwk87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2010, 07:39 PM
  4. Raptor V (SV6)
    By tanner892 in forum Raptor Superchargers
    Last Post: 12-01-2009, 08:02 PM
