Results 1 to 2 of 2
Thread: PERFORMANCE 12mm PLENUM/MANIFOLD SPACER help
    JGlinatsis is offline Ratty
    Vr Executive 3.8 V6
    Apr 2009
    Default PERFORMANCE 12mm PLENUM/MANIFOLD SPACER help
    I want one so bad but i have a VR so the only ones I can find wont fit mine do ther make them for my engine?? if so were from and how much
    N/A
    Apr 2009
    VIC
    No, there's none available for your car. The inlet manifold and plenum are joint, so it is impossible to increase the runner length without modifying it (cutting, welding..etc)
  1. Mace manifold insulator & plenum spacer
    By muzzz89 in forum V6 Development And Modification
    Last Post: 31-01-2012, 10:50 AM
  2. Mace VZ Alloytec manifold spacer?
    By HannibalK1ng in forum Mace Engineering
    Last Post: 03-03-2010, 01:28 PM
  3. Larger throttle body/plenum spacer: worth it?
    By jhawk in forum V6 Development And Modification
    Last Post: 13-02-2010, 06:15 PM
  4. Plenum Spacer
    By dimetime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2009, 07:29 PM
  5. throttle to manifold spacer = power?
    By matty8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2009, 04:12 PM
