Results 1 to 10 of 10
Thread: Roller rocker noise
    VY 03
    Aug 2005
    Exclamation Roller rocker noise
    I was doing some mace roller rockers on another commodore Every thing was going to plan except for 2 of the roller rockers I would try and torque them to 23 But they just kept tightening up. I would even redo one of the others again and it would tighten up and stop at 23nm Where as these other 2 just keep going untill the valve spring is compressed Anybody got any idea why this is happening ? I tried re insterting the pushrod no luck.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    You might have to rotate the engine over via the balancer as there may be too much loads on the springs
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    you need to rotate the engine so that the valves are closed when you torque up the rocker bolts
    Body by Holden, Soul by Brock
    the Legend will live forever
    VT SS LS1
    Oct 2008
    gold coast
    i didnt have a problem. i didnt turn the engine over. although the rockers for cylinder 6 were almost if not fully compressed
    Apr 2006
    Auckland NZ
    you won't get a accurate torque reading when tightening the rocker bolts if you need to compress the valve spring before the rocker bottoms out on the pedestal and the bolt locks up.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    Quote Originally Posted by immortality View Post
    Yep spot on, you need the lifter on the back of the cam lobe.
    http://forums.justcommodores.com.au/signaturepics/sigpic58904_1.gif
    VY 03
    Aug 2005
    After rotating the engine and retorquing the 2 problem rockers they now line up with the others not compressed to the max. 22nm Didn't seem tight but i'm sure its tight enough as instructed.
    Thanks
    VT SS LS1
    Oct 2008
    gold coast
    i was told because of the hydraulic cam and hydraulic lifters that the ecotec uses this isnt nessecary. surely if it was a problem i would of encountered it by 8000km of driving and a fair bit of flogging
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    For accurate torquing down of bolts, the lifters should be on the back of the cam. The hydraulic lifters have a fair amount of leeway but for the sake of 20 extra minutes I would do it properly. If the bolts are too lose then you risk a lot. If they are too tight then unless its so tight that the valve is open when it shouldn't then its not a massive issue, because as I said the lifters have a good leeway.
    Ronald Reagan (1986)
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    didnt use a tourquey and mine are fine, they felt fairly tight when i undone the stockers
  1. Roller Rocker noise on VY
    By mgrb1211 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-01-2011, 11:16 PM
  2. Roller Rocker Installation
    By speed_freak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2010, 03:09 PM
  3. Roller Rocker question
    By KRUPTD in forum V8 Development and Modification
    Last Post: 18-03-2008, 04:33 PM
  4. High Ratio Roller Rocker Arms
    By sickvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-12-2006, 09:00 PM
  5. Another Roller Rocker Question
    By sheldo86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2005, 09:00 PM
