Results 1 to 2 of 2
Thread: l67 manifold insulators + extra boost
    VX Super6 S
    Jul 2010
    Port Augusta
    Default l67 manifold insulators + extra boost
    Hey Mace,
    Have a few questions on your opinion on boost with the l67.
    I am looking to fit a 10psi pulley, high ratio rockers, CAI, and manifold insulators.
    I have read not to go over 10 psi, but if I add a 5% overdrive balancer, that makes it around 12 psi?
    Is that going too much for those mods, I hear it starts to over drive the m90s efficiency. However would the insulators you make help correct that problem? Or would you still just recommend 10 psi. (ie nomal size balancer)
    Also what sizes of the 3 various insulators do you recommend for the l67, and is there clearance issues?
    Mar 2008
    Hey russellvx,
    In regards to your questions/statements…
    “Have a few questions on your opinion on boost with the l67.
    I have read not to go over 10 psi, but if I add a 5% overdrive balancer, that makes it around 12 psi?”
    That’s correct.
    “Is that going too much for those mods, I hear it starts to over drive the m90s efficiency. However would the insulators you make help correct that problem?
    The supercharger insulators we sell would help a little but not enough. The intercoolers we have on offer would certainly help
    “Or would you still just recommend 10 psi. (ie nomal size balancer) Also what sizes of the 3 various insulators do you recommend for the l67, and is there clearance issues?”
    Unless your balancer needs to be replaced I wouldn’t worry about replacing it. As for going higher then 10psi I suppose it depends on what your budget is, bang for buck though I would just stick with a 10psi upgrade now until you start getting hungry for more again
    If you have any more questions please don’t hesitate to ask.
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  1. boost obsession turbo manifold
    By ashzv6 in forum V6 Development And Modification
    Last Post: 16-09-2011, 01:21 PM
  2. Manifold Insulators - What are they?
    By Maccas90 in forum Mace Engineering
    Last Post: 19-07-2010, 09:34 AM
  3. DIY Manifold Insulators?
    By sweefu in forum V6 Development And Modification
    Last Post: 27-02-2010, 02:13 PM
  4. MACE CAI Manifold Insulators ???
    By mattakaspeeedy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-02-2010, 09:45 AM
  5. manifold insulators
    By Archers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-05-2009, 09:58 AM
