Results 1 to 7 of 7
Thread: Mace Performance Products Review
    3.8 VS Ute
    Jun 2010
    Default Mace Performance Products Review
    Hi All
    Just thought i would provide some feedback reguarding the Mace performance products i just installed into my VS 3.8 Auto. The parts were as follows:
    Enclosed pod CAI
    25mm Manifold Insulator
    12mm Plenum Spacer
    1.98:1 Rockers and Crow Pushrods
    Mace Memcal
    My ute already had redback headers, high flow cat and a redback 2.5'' catback. The ute is pretty tidy throughout and has done approx 220 000km, so a good running but relativly tired ecotec.
    Instalation of all parts was very straight foward given the detailed instructions. As i stripped everything down i gave everything a good clean, throttle body, plenum ect. I also installed some reco injectors while i had the thing apart. The best tip i can give you if your installing any of these spacers is to take it easy with the gasket goo. I found that a 3-4ml bead was way more than enough to do the job. I also replaced the throttle body o-ring and rocker cover seals, just to make sure everything was right.
    Test drive was very supprising. There was a much more even power delivery and a substancial increase in torque down low. The engine climbed the revs faster and more easily. The engine overall felt much less restricted. The improved shift points on the memcal were great and overall the ute felt a lot more responsive. There was also a big deepening in the exhaust note.
    After going for a 30min drive i thought i would pop the bonnet and have a feel of the plenum.... cold! very cold. would have only been a couple of degrees warmer than the ambiant air temprature. Great! (my ute is a 1998 VS which does not have an egr valve like the newer ecotecs and alloytecs which keeps thing much cooler).
    I wil try and provide a dyno sheet for the new mods when i have a chance. The pre mod sheet is attached. This is with headers, cat and catback plus a ss inductions OTR CAI and k&n panel filter which i decided on removing due to the heat soak problems i was encountering.
    All in all a great investment and the ute has a heap more poke!!! i would recomend these products as they have made a huge difference to the driveability of my ute. The team at Mace were very helpful and the products were of a very high standard. Thanks Mace
    Attached Images Attached Images
    3.8 VS Ute
    Jun 2010
    If anyone out there has any ideas reguarding further modifications i'de like to hear them. Thinking of going down the forced induction path. Any ideas?
    Shoes
    Aug 2009
    The Racetrack
    you could go something like a raptor supercharger, that should liven the ute up some more.
    its a centrifugal type setup and you'd easily be able to fit it up. runs around 9-10psi boost, and then if you want you can go intercooled.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    3.8 VS Ute
    Jun 2010
    Sounds good. Is there room for further modification with the raptors reguarding intercoolers ect? Any idea what a kit would cost?
    Shoes
    Aug 2009
    The Racetrack
    i think a non intercooled kit is around the $5,000 mark, then intercooled is a bit more. when going intercooled on the ecotecs most people get a reverse plenum so the intake is on the right hand side to make the intercooler piping shorter and less complicated. you should still be able to keep your mace cai i think, as steve from mace and the guys from raptorsc get along pretty well.
    thats $5,000 ish for everything you need inc tuned memcal. then later on you could look at stronger internals and up the boost a bit more, maybe a supercharged specific camshaft to suit the 1.98's as well.
    3.8 VS Ute
    Jun 2010
    thanks for the info old mate. think i might have to save a few pennies before i go down that path. Had a look at the raptor site, great looking set ups for the ecotecs. full kits and the likes. might have to put that idea on the backburner for a while ha ha.
    Mar 2008
    Thanks for the constructive feedback lowwhite, above all though glad to hear your happy with how it's all turned out
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  1. WIN! MACE products by purchasing from MRC Performance!
    By MACE in forum Mace Engineering
    Last Post: 18-04-2011, 02:04 PM
  2. mace products for efi vk commodore?
    By vk.jonno in forum Mace Engineering
    Last Post: 24-03-2010, 09:43 AM
  3. will LPG work with MACE products?
    By fkford in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2010, 12:21 PM
