Results 1 to 20 of 20
Thread: vu s pack ute
    VU II S pack
    Sep 2010
    townsville
    Default vu s pack ute
    Just wondering if u guys have done much work on utes
    Thanks kyle
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Doesn't matter what body you have mate. A VU II S has an Ecotec motor in it and MACE is a specialty in V6's. Have a look through the V6 Performance Parts thread.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VU II S pack
    Sep 2010
    townsville
    So just be under vt yea
    Just don't wana go buy the cam chip package and plenum and manifold Spacer for it to not fit that's all
    VU II S pack
    Sep 2010
    townsville
    I realise this I just wana make sure I'm ordering the right parts don't want to spend $1500 on the wrong bits lol
    Mar 2008
    Hey Kyle,
    We've done heaps of utes over the years so it's not a problem for us
    In your case, bang for buck I would consider the following mods in order.
    Rockers
    Manifold insulator
    Cold air intake
    Plenum spacer
    Larger throttle body.
    If you have any more questions please don't hesitate to ask.
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    VU II S pack
    Sep 2010
    townsville
    VU II S pack
    Sep 2010
    townsville
    Mar 2008
    No problems Large,
    You'll be happy with these
    Steve
    MaceEngineering
    VU II S pack
    Sep 2010
    townsville
    Now I'm looking at cams now if u get stage 2 cam will I also need to get new pushrod and springs or is it just recommend
    VU II S pack
    Sep 2010
    townsville
    Also wat rocker should I get to suit stage 2 cam or should I get cam to suit rockers
    Mar 2008
    Quote Originally Posted by large View Post
    Hey large,
    The bare requirements for the stage 2 COMP CAM, would just be the cam and computer reprogramming itself.
    For a more quality install I would recommend the following
    Stage 2 COMP CAM and tune
    Valve springs 105#
    Retainers to suit
    Shorter valve stem seals
    Inlet manifold gaskets
    Double row timing chain
    Oil pump cover (for chain clearance)
    Can go a 1.75:1 ratio rocker, which we can supply for the job if you wanted more from the cam
    Cheers,
    Steve
    MaceEngineering
    VU II S pack
    Sep 2010
    townsville
    So wat am I looking at for cam and recommend parts without the rockers
    Go Hard Or Go Home
    LIVING LARGE
    Mar 2008
    For a quality install I would recommend the following
    Valve springs 105#
    Retainers to suit
    Cheers,
    Steve
    MaceEngineering
    VU II S pack
    Sep 2010
    townsville
  15. #15
    Mar 2008
    They should be there shortly
    Steve
    MaceEngineering
  16. #16
    VU II S pack
    Sep 2010
    townsville
    Yippe parts arrived today just as described will be putting on nxt wknd cnt wait to feel the result
    Go Hard Or Go Home
    LIVING LARGE
  17. #17
    VU II S pack
    Sep 2010
    townsville
    Hey Steve just curious would these products be able to be painted in high temp paint off course and sand bck the surface area or beta leaving alone
    Go Hard Or Go Home
    LIVING LARGE
  18. #18
    Mar 2008
    They can be painted if you wished using quality automotive paint provided you prep the surface first.
    Steve
    MaceEngineering
  19. #19
    VU II S pack
    Sep 2010
    townsville
    Thanks mace love the product even though lol I got nice fine from wat ure product produced down low ay top job
    A+ product
    Go Hard Or Go Home
    LIVING LARGE
  20. #20
    Mar 2008
    Not a worry large, glad to hear your happy
    On the fine note please take it easy out there.
    Best Regards,
    Steve
    MaceEngineering
  1. My VY S-Pack Ute
    By tysonw47 in forum VY - VZ - WK - WL - V2
    Last Post: 02-06-2010, 08:12 PM
  2. vs series 2 coil pack?? any coil pack will do????
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:52 PM
  3. VR S-pack
    By seabass in forum Parts And Other Items For Sale
    Last Post: 14-10-2005, 11:10 AM
  4. My new VB SL/E 310 Pack
    By Jimbo6443 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-09-2005, 06:15 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
