Well I installed my 25mm manifold Spacer and 12 plenum Spacer on the wknd was exactly 2 hours after installed I got my first fine
A+ for mace products
Go Hard Or Go Home
LIVING LARGE
Took me bout hour to install with couple of beers in there instructions ate perfect even dummy could do this install
Again top job mace
Go Hard Or Go Home
LIVING LARGE
Thanks for the constructive feedback Large, above all I'm glad to hear you're happy with the products
Steve
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
what is the thing in your inlet tubing??? the big round black thing?
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
For the lpg
tuning done by THE1 A+++++ tuner
And powering it by MACE
Build it to handle the MANG
Have to say, I was very impressed with how fast mace sent and i recieved my inuslators. ordered late wed night and i got them early today. (friday) and i live in brisbane coming from vic. was expecting mid next week.
Instructions are good enough for a person with no clue about motors. All they need to know is how to use a socket.
only problem I had is the instructions were for the Vs, and the Vy has a PCV Valve channel and the instructions didn't cover that. I worked it out but. the runnners were easy but the top of the insulator needed to be marked with the factory
gasket to know where to run the gasket maker for the channel in the plenum.
That's a pretty easy fix though. Very easy to figure out.
hmmm i think im going to look into these two products...![]()
Mine didn't come with instructions haha and it was still pretty basic ####
They are fairly straight forward to install, however for people wanting to have a read over the instructions please check out the link below
MANIFOLD INSULATOR VS-VY ECOTEC - Mace Engineering Group
Cheers,
Steve
MaceEngineering
What are the insulators made of??
the insulators are made from bakelite, check it out here,
COLD AIR INTAKE MANIFOLD INSULATOR 25MM FOR HOLDEN VS-VY ECO - Mace Engineering Group
and
Bakelite
Body by Holden, Soul by Brock
the Legend will live forever
why didnt you go the 25 mm plenum spacer, is there a reason or cant you go that big on a standard engine
MaceEngineering
25mm Manifold Insulator and 12mm Plenum Spacer fitted the other day, took roughly 35 minutes all up ( no dicking around ) + a bit longer to let the GOO set, no need for instructions, everything is very basic
Now at idle with the bonnet open the whole plenum is cool to the touch even when the engine is hot-hot, obviously with the bonnet closed this heats up but is still a lot cooler than the intake
Bottom end torque has increased and has also seemed to increased throughout the entire rev range, if I have the wheels on any angle while taking off with anything over quarter throttle it will start to spin the wheels
No modification was needed for my bonnet
Quick and easy mod to do, for the extra low down torque you pick up, it is worth the money
