Results 1 to 7 of 7
Thread: Help! Plz strange noise
    VY Executive V6 3.8L
    Jun 2009
    Default Help! Plz strange noise
    hey all just fitted up maces 25mm manifold spacer and waited for about 2 hours for the gasket to dry and when i started it up it felt like it was goin to die like not all cylinders were going. switched it off and back on and then seamed fine reved it up to 3000 sound sweet then went to test drive around the block but it died when i put my foot down. turned it back on and was doin the same thing as when i first started it. got back home and noticed when i turned the car off and on(only to acc) around the throttle body it make a strange noise like a gurgling grinding sorta sound that goes 4 a good 2 secs. could this b that not all my injectors r in or could it be that with the kit i got 3 diff size hoses and on the fitting instructions it only told me about 2 of the hoses(pretty sure) so i left the thinest hose off
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    no hose thats connected to your intake manifold should be left sucking air
    as it would confuse the computer due to air entering after the sensor
    block off the hose and where it went to to and try again
    if still wont idle
    is likely a vacum leak
    so everything you pulled off would need to be checked if its sealing
    get a tin of carby cleaner and spray around gaskets if revs change when you spray a spot this is where the leak is
    oh and check if you plugged EVERYTHING in around your manifold e.g. unplugged anything you forgot to reconnect
    Jun 2009
    hey thanks for the quick post db_nostso, but still a bit confused
    http://www.maceengineering.com.au/We...TALLATION_.pdf
    thats the instructions i followed. that hose that connects to the manifold you were talking about is it the 1 that plugs in to the throttle body(hose 2 acording to instructions)? cos its not sucking air i dont think, i just replace the old hose with the new hose and connected it up. also if i dont have carby cleaner is it ok to use something els? eg water...
    Jun 2009
    also like to add the car shackes heaps on idle but revs stay normaly around 700rpm
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Has the hose that runs from the throttle body and under the plenum to the connection near the firewall come off ?
    Jun 2009
    nah that all connected the only thing tho is with that elbow piece in the instructions it says to use a pinch clamp to clamp it to the throttle body but i neva had 1 on there in the first place. also like to add i got a 69mm throttle body from mace asawell dont no if that has anything to do with it
    Mar 2008
    Hi hoofelmuma,
    Is the engine light coming on? How does the car idle. Could be a vacuum leak. Best to give us a call tomorrow so we can run through things together quickly.
    Steve
    1300 GO MACE
    1300 466 223
    MACE Engineering Group
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  1. strange noise
    By tenggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2009, 07:36 AM
  2. strange noise NEED HELP!
    By aussie_cruzin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2008, 04:05 AM
  3. Strange noise
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2008, 12:14 AM
  4. Strange noise!
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 06:08 PM
  5. Strange noise
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2005, 01:25 AM
